v0.10.12.x RC4 Testing
Good morning! Windows wallet v.21 still has this problem:
As you can see, there are 0 Anonymous DRK, and plenty of Non-Anonymous DRK but it won't send. Funny thing is if I use "No Preference" then it will send.
Edit: I use the same wallet.dat with the money left over from the previous version.
V.21 will only allow me to input 9999DRK in the Option>Main>Amount of Darkcoin to keep anonymized
Is that suppose to be like that?
I thought the "limit" was lifted.
(To Be Cont'd)... So, because my wallet would not do anymore denomination with that amount, and I could not send by using "Non-Anonymous funds", I went in option and disabled DS. Restarted the wallet and to my surprise this is what I got:
All of the coins suddenly got anonymized!
Edit: And I was able to Darksend some coins away (using Anonymous Funds) despite the DS feature is disabled.
Anybody else's wallet taking a long time to start denominating?
Used an existing wallet.dat and started up the new version (in windows) -- set the number of rounds to 5 and the min anon funds value to over my total wallet balance -- send some coin between wallets then have waited about 20 minutes to this point. Whereas previous versions I got my first denomination fee within 5 minutes, with this version both wallets show no action.
Issue? Or am I not aware of something that needs to be done to get the newest version to start denomination?
I see a lot of "entries(1/2)" and "waiting for more entries(1/2)" in the status readout...
My wallet is still having that problem
2014-08-12 14:56:53 dssu - message doesn't match current masternode - [::]:0 != 211.99.224.173:19999
Does anyone still get this message? I am getting this on my MN running v0.10.12.21-beta (flare's build 20).
The MN config is
rpcuser=darkcoinrpc
rpcpassword=<REMOVED>
daemon=1
testnet=1
onlynet=IPv4
masternode=1
masternodeprivkey=<REMOVED>
masternodeaddr=66.172.33.248:19999
Does anyone still get this message? I am getting this on my MN running v0.10.12.21-beta (flare's build 20, linux 64-bit).
Yes I have a lot of that in my debug log.
Another issue with the GUI causing weird behavior of the client. Tested wit Win32, 0.10.12.21:
The number of darksend rounds in settings resets to 1 with every client restart. (Should the minimum number of rounds not be 2?)
With this wrong setting, I got some change (22 tDRK) to denomitate. After one successful round the corresponding inputs were locked and the client tried to process round 2. After 4 hours and 6 unsuccessfull denomitation rounds with fees, I stopped the client.
Directly after restart, the amount of anonymized funds increased by 22 tDRK. Everything seemed to be ok now. But If I check the inputs with coin control, the 22 tDRK are still at 1 round, leaving them unready for anonymous transfers.
Edit: It looks like the fallback to 1 round setting only takes place if darksend disabled is checked.
Edit2: After correction of the settings,enabling darksend and watching 5 more denominate transactions with fees, my 22 tDRK change is at 2 rounds. Looks like the anonymized balance sometimes includes even funds denominated once.
Looks like evan did some changes within the last hour. Denominating is working again for my wallet
Finally 3000 tDRk anon after 9h with rounds = 4 and no more the 0.001DRK transaction fees for a single one ( V10.12.21 )
It stuck around 4-5 h without doing nothing
I didn't say I can follow, and didn't write any specific address.
I suggest fee has problem. Fee use changed address again and again.
(0.125 -> 0.124 --> 0.123 -->....)
I think anonymous transactions and darksend rounds should use denominated 0.01 for fee not 0.125.
****** Please Update To 10.12.22 or 9.12.22 *******
All fees will use 0.001 sized inputs (they have no change so you can't follow them), all transactions now should look like this one: http://test.explorer.darkcoin.fr/tx/ce0ea2bdf630233955d459489b6f764e0d0bbe9e8a62531dd2a14b455626b59c
- Client now creates fee sizes inputs for use in darksend denomination phases to improve anonymity
- new rpc command erasetransaction. Some users have reported non-confirming transactions due to opening their wallet at multiple locations. This can and will create double spent transactions that will not confirm. erasetransaction is for removing them.
- SplitUpMoney can only execute every 10 blocks now.
- removed matching masternode debugging messages, that's not really an error
- Client now prioritises sending denominated funds back into Darksend. This will improve anonymity and help to respect the "anonymize darkcoin" amount in the configuration.
- fixed a bug where masternodes send failed transactions
- changed max to 100k in configuration
- added a warning message to startup (delete ~/.darkcoin/.agree_to_tou to see it)
- found a bug causing inputs to get locked forever.
- Darksend now checks diskspace before sending anything to a masternode.
- incrementing protocol version to knock all old clients off
Stable Binaries
http://www.darkcoin.io/downloads/master-rc4/darkcoin-qt
http://www.darkcoin.io/downloads/master-rc4/darkcoind
RC4 Binaries ( masternodes / auto-denom )
Stable Binaries
CI-builds for v0.9.12.22-g2e35234
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-97/gitian-win-darkcoin-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...oin-bin/32/darkcoin-0.9.12.22-win32-setup.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRK-81/artifact/QTL/gitian-osx-darkcoin/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-76/gitian-linux-darkcoin-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-76/gitian-linux-darkcoin-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-76/gitian-linux-darkcoin-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-76/gitian-linux-darkcoin-bin/bin/64/darkcoind
CI-builds for v0.10.12.22-g0c9e20d
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/...arkcoin-rc-darkcoin-qt-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...coin-rc-darkcoind-bin/32/daemon/darkcoind.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRKRC-18/artifact/QTL/gitian-osx-darkcoin-rc/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/64/darkcoind
Stable Binaries
Warning message needs 'of' imo
Darksend uses a very large keypool and goes through keys quite rapidly. This means that you need to make backups more frequently than with other wallets, because when it anonymizes your funds a lot transactions happen in the background. To be safe make a new backup after each time your anonymized threshold of funds is reached.
Sound better?
Darksend uses a very large keypool and goes through keys quite rapidly. This means that you need to make backups more frequently than with other wallets, because when it anonymizes your funds a lot of transactions happen in the background. To be safe make a new backup after each time your anonymized threshold of funds is reached.
masternode list in qt client coming up empty on v0.10.12.22-beta
edit: deleted everything except wallet.dat in testnet3 folder and after resync looking better
"108.61.84.37:19999" : 1,
"54.183.79.141:19999" : 1,
"54.191.87.83:19999" : 1,
"54.208.138.69:19999" : 1,
"149.255.109.167:19999" : 1,
"54.64.7.206:19999" : 1,
"184.73.179.196:19999" : 1
