If I run masternode list from the console, my IPs are listed XXX.XXX.XXX.XXX,1 so I'm hoping that all is ok until I turn up in elbereth list! I won't be calm until they have though.
Try this one too http://drk.poolhash.org/masternode.htmlIf I run masternode list from the console, my IPs are listed XXX.XXX.XXX.XXX,1 so I'm hoping that all is ok until I turn up in elbereth list! I won't be calm until they have though.
My MNs appeared there just a few minutes after I started them
If console returns :1 then its all good
I am using the option
in my commandline, and this stops my QT RC4 client from denominating.
The information was hidden in one of Evans' release notes:
I am running v27 without any problems on disabling denom, but i did not use the GUI options dialog. Maybe that setting is ignored.flare, someone on the btctalk thread claimed that disabling DS didn't work for him. I haven't tested this on v.27 so I'm not really sure. But I did test this on a previous version and it worked. Or to make sure after you disable DS, restart the wallet, it should work.
Using disabledarksend=1 works for me.
instead of starting darkcoin-qt.exe directly, create a shortcut to that file, and add the parameter to the Properties. (i do only have german screenshots at hand at the moment, but you should get the idea)Noob question: How do you use this command line in windows wallet? I'm not sure which directory. Thanks.
instead of starting darkcoin-qt.exe directly, create a shortcut to that file, and add the parameter to the Properties. (i do only have german screenshots at hand at the moment, but you should get the idea)![]()
I'm thinking if you disable Darksend before you run the wallet with the MN in it, it should be okay, but I'm not sure. The devs should have a clear instruction on this somewhere.
Maybe this has been answered already but V27 will not kill your MN
you just need the 1000DRK in any addy
and MN=1 in config file
- even if you don't have a MN - it would still work![]()
Yeah, but if you need a new masternodeprivkey you need to set masternode=0 first AFAIK - so it could turn out to be inconvenient to rely on implicit disabling denom.I can also confirm this. If you have masternode=1 in your conf file darksend WILL be disabled by default thus making sure that your 1000DRK will not be denominated.
