daaarkcoins
I doubt you'll be sending >$30,000 to thoseWhat about services that check for only one tx? It will be harder to implement if an automated service if there are multiple transactions.
You do have a point.I doubt you'll be sending >$30,000 to those![]()
so splitting in 5k pieces before denomination is not a solution right?Hmm? I'm not sure where you got this from, but it's not the case at all. The 5000DRK limit is for a hard limit for the entire wallet. Lets say a user has 100k DRK, the wallet would actually end up making a bunch of 500DRK inputs and 100DRK inputs. The only reason I added the hard limit was because there's no easy way to denominate a portion of the wallet without doing the rest.
it was discussed on the previous page..
wouldn't it be possible that the user could determine the hard limit of the wallet?
I just interpreted the size calculation for the transaction - if i got it wrong: my badHmm? I'm not sure where you got this from, but it's not the case at all. The 5000DRK limit is a hard limit for the entire wallet. Lets say a user has 100k DRK, the wallet would actually end up making a bunch of 500DRK inputs and 100DRK inputs. The only reason I added the hard limit was because there's no easy way to denominate a portion of the wallet without doing the rest.
Before DS+ I was hoping Evan would create a similar wallet like the pre-DS+ wallets, which we would just check mark the Darksend box and send any amount of drk and let the network do the anonymizing. Now it doesn't work like that, and DS+ doesn't work with amounts larger than 5000. So does it mean users will need two wallets, one with DS+ and one with no DS+ to be able to do both?
Thanks, Evan. And so far the windows wallet v.17 seems to be doing well.Well once all of the masternodes are running the new version and everyone is updated, I can release that after the fact and it will work without any change to the network.
Yeah, they'd pay the old masternode network until they updated.
I'm not getting this Evan... So essentially there will be two MN active "forks" ? If mining pools do not get orphaned, what will their incentive to update! At best, they might even revert back to the 10% version. It was such a hard battle to get to 95% consensus, if we need to do another round without the "fear" of orphaned blocks... most will just go
"whhat? again? oh bugger off"
I'll be happy to get my hands on some instances6 EC2 instances built and ready to go. I'll keep them running for a month or two. First dev to message me gets them![]()
Wallet is not finished denominating, 100 DRK are at 6 rounds, 2 rounds missing.
