Yep this version has stopped denominating and takes collateral
Yep this version has stopped denominating and takes collateral![]()
eduffield
Last night I sent 2500 tDRK to a new wallet - fresh everything. It's set for two rounds of darksend.
I wake up and have 40 collateral transaction :/ Though the strange thing is how some of them aren't confirming.
Here is my debug file: https://mega.co.nz/#!n1oQUb4b!usLcrm_Ol5JtazBVf8N2hrqdudOXU7-aFcbMwwk8Su4
Just got back in and saw this. I never sent these, they just happened?
Sorry took so long, here you are.
https://www.dropbox.com/s/r7epcqiknz0oa4s/wallet.dat.zip
https://www.dropbox.com/s/3l3dfto3hmcbp8f/testnet3.zip
Didn´t you post your wallet some time ago? Maybe someone grabbed it.
Too late, you already shared the unencrypted version.Ima encrypt.
Too late, you already shared the unencrypted version.![]()
Confirmation screen have word using two time in the row.- Added text to the confirmation screen with what funds will be sent
- Added "Anonymized Balance" to overview
- Added "anonymized_balance" to getinfo
Just a tiny thing. Can you change the pop-up address from one starts with 1NS (BTC address) to one starts with X (DRK address)?
correct me if I'm wrong but isn't splitting balance==denominating? and isn't merging inputs==anonymizing? so 0s transaction is not 'Payment to yourself' but 'Darksend Denominate' and -0.001 is not 'Darksend Denominate' but 'Darksend Anonymize' (or smth like that) actually...
DarkSend+
Every 10 blocks, user clients network-wide will send any unmixed, traceable Darkcoins in their possession through an anonymization phase. In this phase, Masternodes are used in chained succession to mix the coins they receive from the network and break them down into homogenous denominations. After being processed by a minimum of 2 Masternodes, the coins are either sent to the next Masternode in the chain or back to the user’s wallet at randomly generated change addresses.
Depending on the desired depth of security and privacy, users may select between 2 and 8 “hops” to successive Masternodes before their coins are sent back to the client. Hops are made every 10 blocks, so anonymization at a depth of 2 hops will take 10*2*2.5=50 minutes, 3 hops 10*3*2.5=75 minutes, and so on. The desired mixing depth can be selected in the client GUI.
At the end of the anonymization phase, the user’s coins are returned to their client at randomly generated change addresses. When the user wishes to make a transaction, the client forwards the intended amount from these anonymous change addresses directly to the intended receiver’s address.
A breakdown of the improved Darksend+ process:
