chaeplin
moved to inside of loop ;Dchaeplin and elbereth: Added qa11 to qa14 - (all 0.9.12.2) to the feed http://test.explorer.darkcoin.qa/blocks/tdrknxtpayee.json
chaeplin: there is a minor bug in your nxtblpayeeCheck.py script - https://gist.github.com/chaeplin/a295795f3d7124aa77f9#file-a_file-L134-L147
You are initializing the sv0Xpayee variables only once - so if the loop does not find a value, it will use the last found one - instead of "-".
You should reset each
in every round of the loop insteadCode:sv0Xpayee = '-'
and tdrknxtpayee.json and http://tdrk.poolhash.org/ updated
https://test.drk.mn/masternodes.html was updated .. Wow ~ it's auto ? ~~
