v0.10.12.x RC4 Testing
When RC4 is finished this will be the case for sure, but for now i needed to trigger it manually
Nevertheless i did not manage to darksend to another wallet yet, the coins stay in the source wallet...
All you need to do is:
1.) Make a new wallet, put some darkcoin in it
2.) Don't set it up as a masternode, don't encrypt it (it won't ask for the password currently and masternodes aren't supported for darksend)
3.) Wait and every 10 blocks you should see a message in the logs "DoAutomaticDenomination"
4.) If it finds 3 people to merge with, you'll see transactions to yourself.
I've confirmed this works, I have a bunch of transactions to myself as of this morning. But it definitely isn't perfect.
I noticed them on my wallet (unencrypted) I left open. Have like 1300 tDRK like that in several 100 tDRK transactions.
EDIT: All automatic, I did nothing manually (darkcoin-qt 0.10.12.x amd64 on Ubuntu)
EDIT2: THat said I had like 9000 tDRK not denomitated and the wallet stayed online for a full day).
Will have a look - question: is function "darksend <toaddress> <amount>" deprecated due to darksend+?
I have two wallet.
one do AutomaticDenomination, one not.
Only difference is account name .
http://test.explorer.darkcoin.qa/address/moxiL5j5XNGDhZ9LP69CVuE3cKxAfZVLVe -> DoAutomaticDenomination : bunch of list
darkcointestnet@e-H87-HD3:~$ darkcoind listaddressgroupings
            "moxiL5j5XNGDhZ9LP69CVuE3cKxAfZVLVe",
            3973.75964000
            "mtr2hBkaDphWDQWDCXaZHGr4Hu7AWoA1t7",
            903.40400000,
            "0"
            "mmwGeqnnMBRU6cUTP25gZvGi7fsMVSErQX",
            0.00000000,
            "hawk"
            "mtSgTTZ2qeUmHvmNaA9ZQ7TNfCvcJomF7z",
            100.00200000
and
log has DoAutomaticDenomination, but not yet..
darktest@sv2:~> darkcoind listaddressgroupings
            "mzs5Bu8MvD8rjrTrSDTbJfs31fHiTCr5NH",
            500.00000000,
            "mrGzfnjGvFau28v5XeYqnFHMH79rooPEuW",
            160.00000000
            "ms2U1dtG1HLypMiuZR3fMR6BJWie2omDaf",
            0.00000000,
            "n25uMbUfkY2oA5k3Mn8gmb7BaBwz6cMAvv",
            0.01738474
            "n2Uv7ab63kYV2zyZ5pDG1LnPTrAcHiVNUE",
            774.30417376,
            "MINING"
I am currently setting up a stress test for the transaction system: 3 nodes sending random amounts of coins to each other to alternating addresses - lets see if we can handle litecoin/bitcoin trafiic :smile:
More transaction spam!
Currently only fires in semi-auto mode, you have to keep pulling the trigger. I'll upgrade it tomorrow so it just keeps firing by itself until a minimum wallet balance is reached. And maybe just grab the output of 'masternode list' by itself.
edit: now displays remaining ammo at end
spamsend.py
#!/usr/bin/python
import subprocess, random
addresslist = (line.rstrip('\n') for line in open("masternodelist.txt"))
for address in addresslist:
amount = random.randrange(1,10+1)
s = 'Sending ' + str(amount) + ' to ' + str(address)
print s
a = str(amount)
addr = str(address)
subprocess.call(['./darkcoind', 'sendtoaddress', addr, a])
balance = subprocess.check_output(['./darkcoind', 'getbalance'])
print 'Balance remaining = ' + balance
masternodelist.txt:
n463zhqSexzpLtvz1iGmLKGsnRVXdXTCWZ
n3LPtjo2QNUzdpyn3yQkqTDvGn74yTSP7w
n37LjfqZYfyAJdNvp2wpHJbnA9jb4YAtVW
n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o
n2xU4Y743oiWpu1nkHXdvbQTVKTqB8FRKo
n2Wg5yQx258L4emt3tFgrmv9nPnVVi26aB
n23eoeYKnmh8Ybg7U9DQ7kfpsU8N7C6hKZ
n1bb8zU5A3aS1ZoGCLAkggWJnGQdfMkHhR
n1AZHixxuwXH2hTcXyEDu63gBESnRQwier
mzVPa9pUKviaLFYMBcPRxUfG8yALXjHbpa
mzUwVLqv4WMAPbfCJxtG4YfwSjcT5Vt1Em
my63g87UR36Kdov6m2SBMAmRGAsjWSDX7j
mwfrRyK7kpwTqAqdwdwvxWAo21H6MTnEpL
mvrfEXW1ZazecE2cMufCoz2RyGssLwysLr
mubrbRNo51o9sj4hiyFSqkPzUkMEtrao6Q
mu2EV6HqFEDZWdXEKmeNQVGWLxadLPXRAG
msuYaWseCEFm6FtU9iaEPBT6HiSTd4MTDX
mpwjKxJSpTN1LTDbu2BPtXryRpMQi5BSwa
mpuTzSLxMQcSzgdPgs4BHxfCvTSBvWZKF4
mpuD7ci4Y3PA8THoHCWz7GfAZSrnGTSgCf
mmC4xYH8D38h7xsQ8XqfmsTTsaDrdGbHNb
mj79S74NkQbkVnrJq1xyry9K8htg19g9px
mj1eJunhQuBnxShsMxwDKWonANzB3uZsKh
mgLthxzMjabQLnLNZCAcQVxky5JfeiaS8h
mg3NpRmgu4Wv7ARJB3XTEa2vBGKvkgJGNw
edit2: spamsend2.py, full auto spendspam to set minimum balance.
#!/usr/bin/python
balance = float(subprocess.check_output(['./darkcoind', 'getbalance']))
bal = 'Starting balance = ' + str(balance)
print bal
if balance > 50000:
  print s
  a = str(amount)
  addr = str(address)
  remaining = 'Balance remaining =  ' + str(balance)
  print remaining
else:
  print 'Spent to minimum!'
edit3 : crap I've managed to spend some of my original 1000DRK and broken my node.
2014-07-23 03:46:08 found coins 3
2014-07-23 03:46:08  vin nValue 17999220000000
2014-07-23 03:46:08 DoAutomaticDenominating : Running darksend denominate for 179992 coins
spamsend.py
#!/usr/bin/python
print s
a = str(amount)
addr = str(address)
masternodelist.txt:
#!/usr/bin/python
print bal
if balance > 50000:
  print s
  a = str(amount)
  addr = str(address)
  print remaining
else:
It's raining tDRK :grin:
As far as i know the 1000DRK vin gets locked if you issue a "masternode start" - this has to be redone on each restart of darkcoind to lock the vin.
And what can i do with this Darkcoins?
As this are testnet coins and you don't have a Linux system to run a testnet masternode with them, there is not much you can do beside sending them around in the network :smile: (to yourself, to masternode addresses, to a second client you have set up)
So actually you can to everything you can do with real Darkcoins - beside selling :grin:
Interesting: If there is dissent in the network, its not a single node but a cluster which has differing selection - potential root cause for mini-forks...
Evan what do you think?
Also, the dissent is seemingly between versions 91202 and 101203, i.e. between tp2pool (elbereth's tp2pool), nomp (chaeplin's nomp/sv03), non-darksend clients (chaeplin's sv01), and masternodes (the rest).
So it's ok to use windows 32 bit on a 64bit box, right? I tried using my mainnet wallet on testnet, but got no connections, I assume that's what's supposed to happen? rejection?
Anyways, I discovered that to get my masternode to start, I had to have masternode=1 and masternodeprivkey=blah in my mainnet folder (I also have it in my testnet folder) Then I could finally start my master node, and it seams I'm in testnet. I think that's a bit weird. I would have thought that all darkcoin.conf information comes directly from the testnet folder and that the mainnet folder would be completely bypassed if the darkcoin conf says testnet=1
This is why I couldn't get anything to work yesterday.
Ok, anyways, gonna run a wallet on my windows box, mining on my Ubuntu, and masternoding on the Ubuntu as well.
So what I'm interested in seeing is if the funds I just sent to my windows box gets denominated on it's own. Will all the new addresses show up in the address tab?
until about a half hour ago, I was running a mn with the oldest test version. Maybe I caused trouble (I hope ;) that was my intention?? My luck, I had nothing to do with it though, LOL.
Can i get some DRK transfered with Darksend.
I can not send coins "received with Darksend" until i never got some ?
