error, "free variable 'thread' referenced before assignment in enclosing scope"
Fixed: https://github.com/Bertrand256/dash...0.9.12/DashMasternodeTool_0.9.12.linux.tar.gzerror, "free variable 'thread' referenced before assignment in enclosing scope"
Doesn't start, but when I run it a second time, no gui appears but I can see two processes and then they disappear.
What is your Linux distribution/version?
Check if there is anything in the logfile (/home/<username>/DashMasternodeTool/logs/dmt.log)
I'm acting a little blindly because this error doesn't want to show up on my Ubuntu 16.04.
OK thanks. I'll install a linux distro like yours and will check if the error shows up.Dist is manjaro / xfce (arch derivative)
I have installed Manjaro (v17.0.6) but unfortunately the problem does not occur. It remains for me to force python upgrade to v3.6 and then compile binaries. We'll see.Dist is manjaro / xfce (arch derivative)
The manjaro version number doesn't mean very much because it's a rolling a release; latest software with no need for re-installing OS. Did you update your system? Python on manjaro is version 3.6.2-1
Yes, those "generic" alarms are very misleading. I've checked the files with Norton Internet Security and they are ok.I assume that are two false postives, right?
To my Keybase share I have uploaded binaries compiled on two systems: Ubuntu and Manjaro. Both are based on the newest Python - v3.6. Please, give me a feedback whether those files run with or without problems.The manjaro version number doesn't mean very much because it's a rolling a release; latest software with no need for re-installing OS. Did you update your system? Python on manjaro is version 3.6.2-1
URL: https://keybase.pub/bertrand256/dash-masternode-tool/testing/DMT 0.9.12-linux/
Ok, great that you located the cause. Thanks for the feedback.Yep, works flawlessly.
Btw, the previous problem when it wasn't starting, I think it might of been because my tmpfs was full. Anyway, it's working now.
When you close the application, the log should be flushed to disk (it's cached at runtime). I probably know what is the error: there is a new proposal with one of the fields with a different data type than expected. I have fixed this already and will release in a day or two along with other changes I'm working on.Just launched the Proposals window and got the error, "Problems encountered while processing some of the proposals data. Look into the log file for details."
The log file wasn't updated, it's still got an old entry "INFO | __init__ | App started"
@Bertrand256 pls update default DMT RPC nodes (alice and luna) to Dash Core 12.2 to allow DMT to start 12.2 masternodes. Thanks!![]()
