ashmoran
Yeah but I have no tDASH to send to it... And I am not mining on testnet.
Which faucet is this? I have 1300+ tDASH I can return to any faucet … or send to you directly if you have an address
http://test.faucet.dashninja.pl/Which faucet is this? I have 1300+ tDASH I can return to any faucet … or send to you directly if you have an address![]()
Ah, having two different versions (0.12.0 and 0.12.1) of the Dash Wallet on OSX is a bit trickyY
Yosemite 10.10.5
I'll download it on my spare PC. Thanks for the heads up.Ah, having two different versions (0.12.0 and 0.12.1) of the Dash Wallet on OSX is a bit tricky![]()
I've installed the latest testing version to /Applications/Dash-Qt 0.12.1 made a shell script Dash-testing.sh with the following contents:
#!/usr/bin/env shand then I just need to open Terminal and run ./Dash-testing.sh, and it boots up. It's a little bit of a hassle, but not much.
/Applications/Dash-Qt\ 0.12.1.app/Contents/MacOS/Dash-Qt -testnet -listen=0 \
-datadir="/Users/ashmoran/Library/Application Support/Dash-testing"%
I actually have a few of these with various settings on the command line, and I just run the one I want. OS X doesn't get confused (especially if you have multiple copies of the app bundle with different filenames, except that if you want to launch the app from the Dock with the default settings, you have to click on that first, before you run a scripted version, otherwise the Dock icon just represents the first scripted version you launched, and you can't open the app normally.
(cc: @halso)
So, i downloaded 12.1 and set up test net but the QT client says no blockchain available. Where do i get that?I've installed the latest testing version to /Applications/Dash-Qt 0.12.1 made a shell script Dash-testing.sh with the following contents:
(cc: @halso)
It should get that automatically after some minutes. Can you send your debug.log to me?So, i downloaded 12.1 and set up test net but the QT client says no blockchain available. Where do i get that?
Hold on. We are sucking diesel now! All good. Thnks.It should get that automatically after some minutes. Can you send your debug.log to me?
root@atl3:~# ./dash-cli getblockhash 14704
00000006c07b5319449c5cfd9bb91b5282535d4c80d1755150a61a108ebe4aa3
PSing and ISing4 Masternodes updated and reindexed.
QT + 3 mix wallets updated and reindexed. Consolidating fund to mix again.
4 CPU testnet miners up and running (winners list populated and fairly congruent)
All on the same chain
What should we be testing now ?
