Phew! I'm in the right spot.This is test thread :grin:
eduffield crowning
My resolution setting are the same as my previous post - https://darkcointalk.org/threads/v0-11-2-x-testing.4202/page-9#post-47259
Main OS = OSx 10.9.5, Retina 2560 x 1600
VM resized -> odd numbers as I drag the window size
VM full-screen 1280x800 16:10
When it fire up the QT in the VM-resized, it looks like this. You can see the mix buttons, but NOT the bottom corners where the network info is.
Also make sure you have the lastest vmware tools as well sometimes people forget to install the tools on linux and so the resolutions don't change up nicely.Could be VMware reporting false max sizes to the guest-OS. Or not updating the new size information correctly.
Anyway, I'll check this one with VirtualBox (because I'm already using it for other tests) and if it's not reproducible there I'll install VMware.
Almost but later part is quite the opposite actually :smile: PoSe scores is basically an "Error count". So 1% of network check another 1% of network and applies score accordingly. Once you reach some threshold (now it's 6) you will not be count as enabled and as a result you will not be in payment schedule.The PoS (Proof of Service) code performs quality of service checks on the masternodes. The way I understand it then increments or decrements a score based on the results of it's checks. Masternode's with a higher score are performing more optimally.
Edit: that description might be a bit overly simplified maybe someone else can chime in.
Keep up the great work guys. Been nailing it!******************** TESTNET : 11.2.11 - All Users *********************************
- Masternode fixes - Udjin
- CSS / Styling fixes / overview tx table update - Crowning/Snogcel
- Removed DS limit - Udjin
- nScanningErrorCount / nLastScanningErrorBlockHeight storage fixes - Udjin
** Compiling - if you get a 404 try again in a bit
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/DRKW-DEV/JOB1/build-150/gitian-win-darkcoin-bin/32/dash-qt.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DR...1/gitian-osx-dash-dist/dash-0.11.2.11-osx.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/DRKL-DEV/JOB1/build-155/gitian-linux-dash-bin/bin/32/dash-qt
http://bamboo.darkcoin.qa/artifact/DRKL-DEV/JOB1/build-155/gitian-linux-dash-bin/bin/32/dashd
Linux 64bit
http://bamboo.darkcoin.qa/artifact/DRKL-DEV/JOB1/build-155/gitian-linux-dash-bin/bin/64/dash-qt
http://bamboo.darkcoin.qa/artifact/DRKL-DEV/JOB1/build-155/gitian-linux-dash-bin/bin/64/dashd
hmm... took 25 secs for me... anyone else?Loading a fresh wallet on mac is taaaaaking forever to generate teh inital set of keys... Been going on 2 mins only 40%. I recall this only being a 30-45 second process normally.
Windows 32bit:
2015-03-24 16:39:13 Verifying mncache.dat format...
2015-03-24 16:39:13 ERROR: Read : Deserialize or I/O error - non-canonical ReadCompactSize()
2015-03-24 16:39:13 Masternode cache file mncache.dat has invalid format
2015-03-24 16:39:13 Shutdown : done
That's ok, delete mncache.dat once and it should be good (you will need to delete it once again on next release but that should be the last time I believe)Also, on linux masternodes, am occasionally (10% of nodes) getting:
Code:2015-03-24 16:39:13 Verifying mncache.dat format... 2015-03-24 16:39:13 ERROR: Read : Deserialize or I/O error - non-canonical ReadCompactSize() 2015-03-24 16:39:13 Masternode cache file mncache.dat has invalid format 2015-03-24 16:39:13 Shutdown : done
Am having to delete mncache.dat and restart.
And that is not ok. Delete peers.dat and try again.Having issues with latest win build (url above).
First launch stuck "out of sync" with 0 hours remaining.
Launched with -reindex, hung at 6 weeks ago for over a half hour.
Deleted blocks/chainstate folders, launched, churning with many (windows) "not responding" messages.
This wallet has a LOT of addresses/txns from mining.
Previous builds didn't have this issue.
It's behaving like my 11.1.25 wallet. (which also has a ton of addresses/txns)
ubuntu@node-71:~/testnet$ ./darkcoind -datadir=. getinfo
^C
ubuntu@node-71:~/testnet$ tail testnet3/debug.log
2015-03-24 17:42:42 dsq - new Darksend queue object - 107.170.242.110:19999
2015-03-24 17:42:51 CDarksendPool::Check() - entries count 0
2015-03-24 17:43:01 CDarksendPool::Check() - entries count 0
2015-03-24 17:43:03 dsee - Got NEW Masternode entry 172.245.5.168:19999
2015-03-24 17:43:03 dsee - Accepted Masternode entry -1 -1
2015-03-24 17:43:03 CMasternodeMan: Adding new Masternode 172.245.5.168:19999 - 147 now
2015-03-24 17:43:07 dsee - Got NEW Masternode entry 172.245.5.188:19999
2015-03-24 17:43:07 dsee - Accepted Masternode entry -1 -1
2015-03-24 17:43:07 CMasternodeMan: Adding new Masternode 172.245.5.188:19999 - 148 now
2015-03-24 17:43:11 CDarksendPool::Check() - entries count 0
ubuntu@node-71:~/testnet$ date
Tue Mar 24 13:52:47 EDT 2015
ubuntu@node-71:~/testnet$ kill -9 18985
Dash server starting
[email protected]Done. same issue. Care to try with my uber-tdrk-rich wallet.dat? :wink:
are you sure you are on latest version? that was a known issue and should be fixed now...Also, need to report some linux masternodes hanging.
Having to kill -9 and restart.
(dashd is symlinked to darkcoind)
Nothing telling in logs:
Code:ubuntu@node-71:~/testnet$ ./darkcoind -datadir=. getinfo ^C ubuntu@node-71:~/testnet$ tail testnet3/debug.log 2015-03-24 17:42:42 dsq - new Darksend queue object - 107.170.242.110:19999 2015-03-24 17:42:51 CDarksendPool::Check() - entries count 0 2015-03-24 17:43:01 CDarksendPool::Check() - entries count 0 2015-03-24 17:43:03 dsee - Got NEW Masternode entry 172.245.5.168:19999 2015-03-24 17:43:03 dsee - Accepted Masternode entry -1 -1 2015-03-24 17:43:03 CMasternodeMan: Adding new Masternode 172.245.5.168:19999 - 147 now 2015-03-24 17:43:07 dsee - Got NEW Masternode entry 172.245.5.188:19999 2015-03-24 17:43:07 dsee - Accepted Masternode entry -1 -1 2015-03-24 17:43:07 CMasternodeMan: Adding new Masternode 172.245.5.188:19999 - 148 now 2015-03-24 17:43:11 CDarksendPool::Check() - entries count 0 ubuntu@node-71:~/testnet$ date Tue Mar 24 13:52:47 EDT 2015 ubuntu@node-71:~/testnet$ kill -9 18985 ubuntu@node-71:~/testnet$ ./darkcoind -datadir=. Dash server starting
[email protected]
ssh 080 'cd testnet; ./darkcoind -datadir=. getinfo'
"version" : 110211,
"protocolversion" : 70075,
"walletversion" : 61000,
"balance" : 1417.40004000,
"blocks" : 25273,
"timeoffset" : 0,
"connections" : 9,
"proxy" : "",
"difficulty" : 0.01531988,
"testnet" : true,
"keypoololdest" : 1425796679,
"keypoolsize" : 1001,
"paytxfee" : 0.00000000,
"relayfee" : 0.00001000,
"errors" : ""
hmmm...Sent!
And yes. Feels like a regression.
Code:ssh 080 'cd testnet; ./darkcoind -datadir=. getinfo' { "version" : 110211, "protocolversion" : 70075, "walletversion" : 61000, "balance" : 1417.40004000, "darksend_balance" : 0.00000000, "blocks" : 25273, "timeoffset" : 0, "connections" : 9, "proxy" : "", "difficulty" : 0.01531988, "testnet" : true, "keypoololdest" : 1425796679, "keypoolsize" : 1001, "paytxfee" : 0.00000000, "relayfee" : 0.00001000, "errors" : "" }
is quite an edge case if you ask me :wink:Keys: 84058 plaintext, 0 encrypted, 81020 w/ metadata, 84058 total
hmmm...
PS. 50+ Mb wallet![]()
