I dived straight in and tried dash on mainnet, it works and receives coins ok.
set
listen=1 in the dash folder config and you can run 2 wallets at the same time.
The instantX transmission is being received as normal proof of work in the dash wallet from the darkcoin wallet (or the question mark indicator is wrong)
The instantX transmission from dash to the darkcoin wallet is
working and checked, but again there is a question mark on the instantX transmission in the dash wallet after sent.
at 17.38 still not confirmations.
edit: instantX definitely is not working back to the same dash wallet - it goes to default proof of work.
debug has 100's of errors like this,
