v0.11.1.x InstantX Testing
just a idea.
would be great to see how I send out the coins (recent transaction & transaction details).
a DS & instantX transfer switch to this after reopening the wallet :
Status: 95 confirmations
this would be better in my opinion:
Status: 95 confirmations (DS & iX)
...maybe with smart designed symbols in the recent transaction if someone redesigns the GUI in a later state of development.
we have some unique features here. we should show them in a clear way.
11.1.6
send all coins to a new adress in the wallet to DS from the scratch.
the DS completion bar has missed my action and showed something strange. not a functional problem. just optical.
btw. the wallet feels sluggish quite often
I have very strange issues with DS, particularly with the final balance after the mixing process.
I tried to send all available ds balance to other address to start mixing after that with different settings but got this one.
The final balance usually exceeds the initial one which I selected for mixing purposes.
View attachment 885 View attachment 886
As you can see, there are hidden ds balance which shows up when I send all available coins ..
debug.log please :wink: [email protected]
I have a transaction that is almost a day old with 0 confirmations. Is there a way to reverse a transactions that doesn't have any confirmations? Transactions sent after this "stuck" one have gone through.
it most likely stucked on forked chain, run wallet with -zapwallettxes command-line option to clear it
Sorry, I deleted my last two posts when I realized I didn't use InstantX (too early for me and haven't got enough caffeine!)
This time I just Darksent another IX transaction (the InstantX box was checked) and this is what it shows:
EDIT: Darksend mixing was off during this transaction.
I just started the DS mixing, then Darksent another InstantX transaction, and this is what I've got:
(not sure if the DS mixer is on, it has any effect on IX, just stating here. )
Oddness:
Before I started 11.1.6 I deleted the masternodeprivkey from my .conf and set masternode=0 as I wanted to test DS.
If you set masternode=0 you can leave the masternodeprivkey in place, it wont be read. Unless you touched your 1k deposit, then yeah, its advisable to create a new one.
Well, progress is calculated from 2 parts now:
1) denomination part: ( sum of all ("input amount" x "input rounds" ) ) divided by ( "number of rounds you want to mix" x " funds that are represented by denominated amounts")
2) anonymization part: "darksend balance" divided by "darkcoins to keep anonymized"
Total progress is #1 * 80 + #2 * 20
So if there was a bunch of large inputs that went through another round or two it's quite possible to see big jumps
EDIT: + what Evan said ))
Could you explain this again in numbers. I'm not sure what you mean by "input rounds". And I guess "input amount" means the total coins in the wallet?
Thanks! :)
I've tested InstantX and there is my small report:
1. I've got 1000 tDRK.
2. I send 100 tDRK to y4EVP3EWvt9gt7AeU3xGZD3uZvc4xy1L26 and I've got status, that verified via instantx.
3. I try to send another 100 tDRK and get "insufficient funds" error.
All transactions are not DS+.
When you do "getinfo", what's the "walletsize"? I think normally the older walletsize 60001 has this problem.
I made wallet from the scratch.
"version" : 110105,
"protocolversion" : 70057,
"walletversion" : 61000,
"balance" : 900.00000000,
"blocks" : 103196,
"timeoffset" : 0,
"connections" : 3,
"proxy" : "",
"difficulty" : 0.13803613,
"testnet" : true,
"keypoololdest" : 1423080953,
"keypoolsize" : 1001,
"paytxfee" : 0.00000000,
"relayfee" : 0.00001000,
"errors" : ""
wait till its confirmed POW 6 times and then try to send those other 100 tDRK
"version" : 110105,
"blocks" : 103196,
"timeoffset" : 0,
"connections" : 3,
"proxy" : "",
"testnet" : true,
"errors" : ""
I haven't had this issue. Can you download the latest version and try again and see if it still happens:
https://darkcointalk.org/threads/v0-11-1-x-instantx-release-testing.3826/page-16#post-40152
