moli
OH thanks. I need new glasses .. lol"Compiling: If you get a 404, try again in a few minutes"
Generated 624 translation(s) (624 finished and 0 unfinished)
Ignored 284 untranslated source text(s)
Updating '/exports/src/git/v0.11.1.x/src/qt/locale/darkcoin_es.qm'...
Generated 908 translation(s) (908 finished and 0 unfinished)
I take it that it's very cool, only I don't understand it, LOL.Hey, how cool is THAT:
Code:Generated 624 translation(s) (624 finished and 0 unfinished) Ignored 284 untranslated source text(s) Updating '/exports/src/git/v0.11.1.x/src/qt/locale/darkcoin_es.qm'... Generated 908 translation(s) (908 finished and 0 unfinished)
The locale stuff gets automatically updated during a build![]()
eduffield needs to _start_ the build :wink:
Edit: OSX build was started a minute ago :grin:
Edit^2: Windows link works now.
I just decided to finish mixing the coins in my test wallet. It was at, I dunno, 60%, I walked away, and came back about 5 minutes (tops) later and I'm at 89% complete on 8 rounds. Now I know the estimate isn't super accurate, but this seems really fast. Did something change?
Can we not IX during mixing, even when we choose non denominated coins in coin-control?
Is it on purpose or devs are trying to fix it?
Second attempt worked. I think I chose new coins to send.IX Requires inputs that have at least 5 block-level confirmations. So, if you mix and let them sit for 10 minutes after they're done, IX will work.
Maybe that should be represented in the balance on the send screen when you click IX?
Yes, with some additional info that your balance may be lowerIX Requires inputs that have at least 5 block-level confirmations. So, if you mix and let them sit for 10 minutes after they're done, IX will work.
Well, progress is calculated from 2 parts now:
1) denomination part: ( sum of all ("input amount" x "input rounds" ) ) divided by ( "number of rounds you want to mix" x " funds that are represented by denominated amounts")
2) anonymization part: "darksend balance" divided by "darkcoins to keep anonymized"
Total progress is #1 * 80 + #2 * 20
So if there was a bunch of large inputs that went through another round or two it's quite possible to see big jumps
EDIT: + what Evan said ))
Yeah, the DSTX message is now supported by the protocol, meaning the DS transactions are first class citizens in blocks and get mined right away. Sometimes, It took 30 minutes before.
EDIT: + what UdjinM6 (We both fixed it separately :grin![]()
The IX confirms will confirm faster than POW confirms anyway. As it currently stands, it's for mainly for merchants to know that the coins actually are theirs since you can't immediately reuse received IX tx's to send to someone else.Just finished some throwing some tDRK in #darkcoin and observed that you can't spend iX coins until they've fully confirmed. Any plans on including some sort of measure on what these coins can be spent in the wallet? Right now I'm assuming I need to wait for 6 confirms + iX confirms (12 confirms according to wallet) - is this correct?
Status: 5/confirmed (verified via instantx), has not been successfully broadcast yetPlease anyone send me some to my testnet wallet:
y4EVP3EWvt9gt7AeU3xGZD3uZvc4xy1L26
Thank you
