Fixing the bug with the massive amount of spam, should be compiled in a sec
Updated to v0.10.9.6-4-gf83bb9e-beta - log spam gone. Thanks!
EDIT: Nevertheless the load by darkcoind process is 100%
EDIT: Updated to v0.10.9.6-5-g78318bb-beta aka 10.9.7 - load normal again :smile:
EDIT: user error. Debugging brain.
Updated !
And this time it instantly got picked up by chaeplin's list. Hope to see payments soon.
After sending the local wallet offline, when you start it again after a while (for example to send payments to main wallet or paper wallet), does one only do "darkcoind" or also do "darkcoind masternode start" ?
EDIT: Got my first payment, 15.1 DRKs ;)
Awesome, so it looks like we're in business.
Hi Evan, i can confirm the TTL code for masternodes is working now :smile:
Started node 184.73.179.196 and shut it down at 19:41:35 UTC. Exactly 30minutes later at 20:11:42 UTC the node was marked inactive ':0' in the masternode list. Note: During this time the node still received payouts/votes.
Good job, well done!
Please send one million testnet coins to this address. muiTvwg8sHmdWsNrfGqm4rM1Z2bHgzr1TD Thank you.
Edit: Also masternode list is only showing one MN currently. Is this correct?
"184.73.179.187:19999" : 1
This might be a stupid question. I'm using the forkfix branch and built darkcoin-qt.
I do not see the 'masternode start' command or 'masternode genkey' command.
