Ignition75
Active member
Still want some testnet hashing? I've got a 36 Mh/s rental that shouldn't break anything.
Incoming...i dont think anyone would object to more hashingthanks
2.) Please point your miners here:
http://ec2-54-197-169-85.compute-1.amazonaws.com
(You can use username: eduffield.1 and password:x, or simply sign up)
Moli was able to follow an 8 round DS back to her starting point looking at the power of 2s in the block explorer:
Code:[14:59] <moli> ok i start with this screen: http://test.explorer.darkcoin.fr/tx/460a41e4e3b3b873aea919dc49691e8d335a06ba4cab897ce3c0afea9d0f4246 [14:59] <xolbo> Yep [15:01] <moli> if you click on the first tx, amount 10 [15:02] <xolbo> go on [15:02] <moli> it takes you to this screen: http://test.explorer.darkcoin.fr/tx/6f1376b52a249d54ad5fbe375cad996189077eb8fea335413855b08342b9946c#o39 [15:02] <moli> those numbers 2, 4, 64, 128 aren't it [15:02] <moli> but indexes 7-10 [15:02] <moli> click on any of those indexes [15:03] <xolbo> Alright [15:03] <moli> index 7: http://test.explorer.darkcoin.fr/tx/36c659cb61fe58f19766210d0a66aee0ff3bc2e0d41ad07c61b978f59bd8dc95#o18 [15:03] <moli> and then you see amounts 8, 16, 32 [15:03] <moli> those are the keys [15:04] <moli> my origin: http://test.explorer.darkcoin.fr/tx/c2fbb9db3251a3cf825d8b5a2e32eba39d7dd6d9aa07a157e8ec6ede6b55a474#o8
They are the standouts in the explorer vs just having .1, 1, and 10s. So instead of going down a goose egg hunt of similar denominations, you disregard anything that isn't a power of 2. Narrows the pool severely.
EDIT: Is there a way we can do without the powers of 2 to keep the inputs denominations that will actually continue to be used throughout due to everyone darksending .1, 1, and 10s?
Your welcome to point it back at my p2pool.My rental doesn't want to connect, sorry.
i think we need to discuss this a bit more or get a reply from Evan on this matter, does the use of the power of 2 form a vulnerability in that the starting point can be traced back more easily on Mainnet ? i do realise there is a difference between Testnet (few testers) and Mainnet (a lot of users) but still .....
Done and hashing...Your welcome to point it back at my p2pool.
-o http://test.p2pool.masternode.io:18998 -O mpyoND6JcQupEjkjiQw1MRoTE2koREkFzd:xyz
I have added some swap space so even if it overwhelms it now it can at least swap some stuff out of memory. Didn't realize until last week that vultr's base images have zero swap configured.
Evan, that was my discussion with oblox in IRC. I had about 322 tDRK anonymized with 8 and 9 rounds as you can see from my previous post:This input? It only went through 1 round:
1.) Click the first 10
2.) Click index 7
should be here now:
http://test.explorer.darkcoin.fr/tx...d0a66aee0ff3bc2e0d41ad07c61b978f59bd8dc95#o18
To which he says this is the source? Isn't that 1 round, not 8?
2.) Click index 7
should be here now:
Wow, this version really does it quick. Almost done 2000/4 - but lots of 5 rounders in there.
Yep~ Same thing happens here.damn, i was just about to write a post that the darksend rounds look fixed now
6x 1000 wallets set for 950 / 4 rounds, 2 of those wallets finished with 100% (with all 4 rounds) or were about to finish (1 round to go to make it round 4) at which point i changed my mind about the Darksend amount / rounds, stopped the mixing and adjusted the Darksend amount / rounds to 990 / 8 rounds of all 6 wallets.
So far the rounds are not exceeding the set 8 rounds, there is however some mismatch between set amount and the achieved Darksend Balance ... for example this wallet which finished all its input amounts with 8 rounds, i was exspecting my Darksend Balance to be a bit more higher i guess...
I will check the other wallets for the achieved Darksend Balance tomorrow as they are still mixing right now.
Edit : another wallet finished with all input amounts on 8 rounds, see difference between Darksend Balance and Darksend Amount of both wallets :
eduffield: I have a request: Would you let us have a choice to anonymize for more than 8 rounds, up to 20 rounds? Even if users have to pay for some fees for more than 8 rounds, I think it's worth it. What say you?
Sounds good. But there're people who don't want to use Darksend, not sure if it's a good idea to have DS enabled automatically.Change to periods up to x number, each period represents 8 rounds. Defaults to 1 which means everyone automatically when they start DS goes 8 rounds.
