MN's do deem to be taking a bit longer to propagate through the network as active with recent versions.Anybody have any idea why my MNs are not showing on the MN list? I've updated my MNs to 10.16.15 and I did "masternode start" from local and got "masternode successfully started."
Hi David, try removing the peer file in the %appdata% Darkcoin folder
Remove peers.dat on both.On the remote or the local?
P.S. I started them last night!
I thought of that kind of checks too. But it's dangerous to ask from other nodes.Quick idea (right now I'm at work and can't test this):
When the bad node registers let the other nodes ask THAT IP-address for the corresponding vin (or pubkey or whatever else is easy to access).
No correct answer, node not accepted.
- it's a honest node -> it will give you the correct answer
- it's the bad node -> the 'good' node (which owns the physical address) is connected (we don't talk about IP-spoofing here, don't we?) and gives you the wrong answer (it can't return the bad node's vin/pubkey/etc. because it has no idea what's going on).
No doubt. Lack of any mention to the feature's limitations/condition will cause that... Flare came along and cleared it up, now I have no problem with it.Don't use features you don't know about/havent seen documentation and you'll be grand... aimed at you as well camosoul
As always a relevant http://xkcd.com/293/
I thought of that kind of checks too. But it's dangerous to ask from other nodes.While dsee propogate EVERY node will ask THAT IP if it's legit. That could lead to DDoS from the network to legit IP.
EDIT: ignore this answer I was wrong - it will not propagate
EDIT2: However one can get MN list and send dsee to every MN manually for example and they will ask legit
That makes sense... however you can point WHOLE MN network to some IP that is not even a MN.... And run this as many times as you want simply changing target IP... Or even your own... OMG... We are building an ION CANNON!! :grin:A time-out for the legity responses would take care of this. IP a.b.c.d wants to register but already tried 30 seconds ago -> ignore and keep the Masternode you already have for that IP. No DDoS...
Could hide the real MNs in a haystack of fake ones?That makes sense... however you can point WHOLE MN network to some IP that is not even a MN.... And run this as many times as you want simply changing target IP... Or even your own... OMG... We are building an ION CANNON!! :grin:
Faking MN/IP (i.e. multiple vin on same IP?) gives nothing but few $$ you can save on hosting + you disturbing MN network a little(? should read some code beforeI guess if someone successfully fakes lots of Masternodes/IPs he can do this anyway...
(? should read some code before).
Hahaha)) You wouldn't believe! :wink:ConnectNode() is your friend :wink:
Liking the "Official Darkcoin Dev" title, bud! Looks good on ya! Looking forward to seeing more of your work...Hahaha)) You wouldn't believe! :wink:
Are you spying on me? :what:
:grin:
Let's guess: Xb8rhXiFwjk6gN8huQZWE8nVFwXxeVS5ygAswan, can you find the origin address of this transaction: d06e7cd0726f693b9133ed2be5505312d9fdfa18f60deb7e7a7d2423ff4b5b25 ?
Or if anyone else can find it, I'll be happy to know. Thanks.
:smile:
Guess again. :smile:Let's guess: Xb8rhXiFwjk6gN8huQZWE8nVFwXxeVS5yg
Btw I found this tx http://explorer.darkcoin.io/tx/31e335eb737f01cf451805f03b47adfc9cb0493f61604a798582d6e645ce9ab5
I know it's DS and fee will be charged randomly but 50Kb+ transaction for 0 fee...![]()
(This isn't my tx but I was told to ask you guess again, and guess whose this tx is? ) :smile:
Edit: I made the same guess the first time too, but he said it wasn't it.![]()
