v0.10.13.x RC5 Testing
10.13.01 and 9.13.01 have a different chain. Had to delete the blocks and chainstate directory.
9.13.01 chain
blocks: 36913
difficulty: 0.00074016
10.13.01 chain
blocks: 25575
difficulty: 0.041077215
Edit: Please send me some money. :) n29sEqngo3pgB8Yesj9HJgNcN8umtD4HsX
9.13.01 chain
blocks: 36913
10.13.01 chain
blocks: 25575
darktest@sv1:~> darkcoind sendtoaddress n29sEqngo3pgB8Yesj9HJgNcN8umtD4HsX 2500
774d0e68acb31ff359f812a6ca4f16932a027cab5056d331a4da158a35dc9143
darktest@sv1:~> darkcoind getinfo
"version" : 91301,
"protocolversion" : 70035,
"walletversion" : 60000,
"balance" : 440753.62623875,
"blocks" : 25578,
"timeoffset" : 0,
"connections" : 13,
"proxy" : "",
"difficulty" : 0.40630270,
"testnet" : true,
"keypoololdest" : 1409606282,
"keypoolsize" : 101,
"paytxfee" : 0.00000000,
"mininput" : 0.00001000,
"errors" : ""
Hurrah, got to take my magic toy out of the secret drawer again!
n1GMK7vnoKLkxVRf9kCcP4VX9FuENWvxun - can I please some dotations ? :D or is there a faucet?
9.13.01 chain
blocks: 36913
10.13.01 chain
blocks: 25575
maybe try a resync from scratch ? 9.13.1 should be according chaeplin on "blocks" : 25578
or a -reindex ?
Extremely small issue, but there is a typo in the initial splash screen...an extra space before the period in "Please don't run the software in more than one location at the same time ." (Last paragraph).
Also in the third paragraph "...because when it anonymizes your funds a lot transactions" should be "a lot of transactions". Also, same paragraph, "To be safe make a new backup" should be "To be safe, make a new backup." (Missing comma). Same paragraph, "To be safe make a new backup after each time your anonymized threshold of funds is reached" might be more clear if it said "your threshold of anonymized funds."
NOT trying to nitpick, but I can't code at all, so maybe this helps in some small way =)
I don't know what I'm doing wrong, but every time I go to get on testnet, darkcoin-qt loads regular (beginning with "x") darkcoin addresses. My darkcoin.conf says "testnet=1"
Can somebody help?
Can somebody help?
If you are using windows go to folder options and allow known file type extensions to be seen. Then go back to the darkcoin directory and rename the config file from darkcoin.conf.txt to darkcoin.conf
They are. The file is actually darkcoin.conf
It's a blank file, nothing in it, just the following:
testnet=1
I could use some testnet darkcoins:
n1B6eiYtM1BgLLR74BhV9aZ1M8ntTnT96v
Thanks!
darktest@sv1:~> darkcoind sendtoaddress n1GMK7vnoKLkxVRf9kCcP4VX9FuENWvxun 2500
efc82a93e3928a8d71d0a2dd5c697d76ee341c922e8422e18eb4d0e2a1280372
darktest@sv1:~> darkcoind sendtoaddress n1B6eiYtM1BgLLR74BhV9aZ1M8ntTnT96v 2500
6353a9cdfa4c8a51e2d12da9ad9fa0787e03eedecd3b6d29f65775680fb04d2a
Seriously have no idea why it wouldn't be parsed then. Maybe a spelling mistake?
You could launch it manually from cmd prompt if need be with the -testnet flag.
To david :
in the shortcut make sure it targets to yr testfolder, with me it has been setup as follows :
D:\DarkcoinTest\darkcoin-qt.exe -datadir=D:\DarkcoinTestData
The -testnet flag did it. Bizarre. No spelling error! Thanks for your help =)
Now can I get some tDRK pretty please? =)
mrAUJXxZ4ZH4cbzx9Yf4V8Y7zP8z86CVBi
I have coins in my wallet from the previous windows wallet version 10.12.32. Installed the new wallet 10.13.1. With 2000 tdrk, set amount to be anonymized: 500, rounds: 4. It started to get the rounds finished but I notice round numbers such as: 1.67742/4, 1.1/4, 2.3871/4, 3.48387/4 .... Unlike normally the rounds would not be a decimal number.
Could someone explain what it means?
Edit: 498 coins got anonymized pretty fast though! :)
