I've just pointed some hashing power at -o stratum+tcp://54.91.161.78:3333 -u eduffield.1 -p x
and I'm getting "waiting for work to be available from pools"
Now I get:
I did set it up to 0.001
This is mostly MN related right? No need to get involved otherwise?
could someone in charge please verify the test faucet, i sent 8000 tDRK to it but it still mentions :
Get testnet coins:
Send testnet DRK 0 to:
Just running a testnet wallet helps. The more the merrier
I'm waiting for the windows wallet. Is flare with us ?
****** PLEASE UPDATE TO 9.13.0 OR 10.13.0 *******
RC5 Binaries ( masternodes )
http://www.darkcoin.io/downloads/rc5/darkcoin-qt
http://www.darkcoin.io/downloads/rc5/darkcoind
darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped =26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped
$ ./darkcoin-qt -testnet bash: ./darkcoin-qt: cannot execute binary file: Exec format error
I'd like a 32-bit version of the darkcoin-qt binary. This appears to be 64-bit based on the output from "file":
Code:darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]darkcoin-qt: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped =26d75c01723f49193ab1ba2af7e7bac552d76c70, not stripped
git checkout remotes/origin/master-rc5
"version" : 91300,
"protocolversion" : 70035,
"walletversion" : 60000,
"balance" : 1050.00000000,
"blocks" : 36873,
"timeoffset" : 0,
"connections" : 1,
"proxy" : "",
"difficulty" : 0.00024414,
"testnet" : true,
"keypoololdest" : 1399764661,
"keypoolsize" : 86,
"paytxfee" : 0.00000000,
"mininput" : 0.00001000,
"unlocked_until" : 0,
"errors" : ""
I`M IN Downloading the binaries wallet only and denominating all the way long....
EDIT: downloaded binaries but can`t start them on windows, where can I find the qt for windows?
