v0.10.13.x RC5 Testing
****** PLEASE UPDATE TO v9.13.2 (Stable) OR 10.13.2 (RC) *******
- Easy to read darksend progress bar (Mouse over for very detailed info)
- Fixed a collateral bug
- Moved around the overview screen, changed some of the text
- Removed lots of debug messages (they show up only with debug=1 now)
Stable Binaries
http://www.darkcoin.io/downloads/master-rc5/darkcoin-qt
http://www.darkcoin.io/downloads/master-rc5/darkcoind
RC5 Binaries
http://www.darkcoin.io/downloads/rc5/darkcoin-qt
http://www.darkcoin.io/downloads/rc5/darkcoind
Not to hero worship too hard, but I'm stoked at getting a personal reply from Evan on the collateral thing!
OK, I have a problem.
Scenario:
Using version 10.13.1, I had taken 1000tDRK from the faucet, set Darksend to 8 rounds and amount to keep anonymized 800tDRK. Everything went well, after less than 2 hours the wallet anonymized the whole 1000tDRK. Then I sent 26tDRK anonymous back to the faucet, all good.
Then version 10.13.2 came out so I updated, went to the faucet and grabbed additional 3000tDRK, since I had my setting to keep anonymized at 800tdrk I figured I would go in and change that to 2000tDRK instead. When I hit apply on the settings screen, the wallet freezed.
I had to force quit, when I ran the wallet again, it open up OK, I went again to settings clicked OK and it froze again:
Now it freezes every time I go to Options and press OK until I have to force quit.
Edit: If I just leave it open without going into Options, it wont freeze but Darksend stays idle.
Edit2: Just posted on Jira, I hope it helps.
Here are the latest CI-builds
CI-builds for v0.9.13.2-g041a043
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-114/gitian-win-darkcoin-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...coin-bin/32/darkcoin-0.9.13.2-win32-setup.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRK-95/artifact/QTL/gitian-osx-darkcoin/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-93/gitian-linux-darkcoin-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-93/gitian-linux-darkcoin-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-93/gitian-linux-darkcoin-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-93/gitian-linux-darkcoin-bin/bin/64/darkcoind
CI-builds for v0.10.13.2-g70ca097
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/...arkcoin-rc-darkcoin-qt-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...coin-rc-darkcoind-bin/32/daemon/darkcoind.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRKRC-32/artifact/QTL/gitian-osx-darkcoin-rc/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/64/darkcoind
Is there an easy way to setup an if statement that used logic to disable darksend when the coins are within say x% of the threshold?
Testing qt wallet v0.10.13.2 in Ubuntu 14.04. Sometimes my wallet refuses to show menu in system bar (at the top of the screen). But it happens kind of randomly for me - sometimes it's ok and another time it's not. Tried both wallets (from Evan and Flare) - result are pretty much the same. Can anyone confirm this please before I add this to jira or is it something wrong with my PC?
10.13.2 here. Set it up to 500 coins and it did 858.
This was explained a few pages ago. That number is more like the minimum DRK to have anonymized.
Evan: The wording of that setting needs to be changed or so some of info on mouse over added.
I'm not much help but if you can keep reproducing it then I'd raise it on jira anyway. I'm a big fan of report everything since the developers should rank the bugs in risk order.
A
i thought this issue was raised on jira but I can't find it. Could you raise a ticket? I can't do it on my iPad :-(
A
And I am on my iphone:tongue: I am sure somebody will be nice and add the issue... if not then I will do it when I get back from work.
One question, after you anonymize funds for the first time and you have an anon balance, then you add new funds to your wallet, how do you make Darksend denominate and mix the new funds? I cant get it to mix the new coins although I raised the amount to keep anonymized. Is there a command or something? What should I do?
It should happen automatically. How long did you wait?
Update on my denominating - I'm an idiot - lol
I was running my wallet with masternode=1
No wonder it would not denom - lol
All good now :)
No collateral fees yet...
All good now :)
edit: 4/4 completed but I asked it to do 1000tDRK out of 6075tDRK and it preformed 1958.0000002tDRK
Well... http://jira.darkcoin.qa/browse/DRK-50
Noted that in such situation icon disappears too. Also getting this kind of behavior more frequently when my CPU is at ~100% by another process but I'm not sure if this is related in any way.
Maybe I was just impatient, had to leave the house. I am on my cell now will check later. Anyway, the first time it was pretty much instantaneous when I had no anon funds, second time I wasnt sure what to expect as to when the process should/would start again. It just kept showing 100%, like I said maybe I left too soon. But something like new non anon funds detected... denom should start shortly would be great.
Latest test wallet, changed the threshold to 100 and 6 rounds. The 78 or so I had anon'd are back in the normal balance. No denominating for the past 2 hours. I have seen it say idle, your transaction was accepted into pool, and submitted to masternode (1/2).
