Thanks a lot! It woked. when i start my mainnet wallet should I remove the darkcoin.conf file? Will I have to sync with the weeks of blockchain again?Start your wallet with "testnet=1" in darkcoin.conf
check the tx you sent, I think 1000 tdrk is vout #1 and payout is vout #0Evan, something is odd, my normal client (0.9.12.0) which is solomining is receiving masternode payouts
Code: [ { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 41.60000000, "confirmations" : 17, "generated" : true, "blockhash" : "0000000066a3f44cd4ed54d900fc2f2fa145fec7f9da4ad5344ad7df70961c3d", "blockindex" : 0, "blocktime" : 1405841190, "txid" : "c13e2d0604d3cb54ca000590b264c2605ee85511200a0a1cda08f8c17535df93", "time" : 1405841190, "timereceived" : 1405841210 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 39.60000000, "confirmations" : 14, "generated" : true, "blockhash" : "000000009fbc7d39248cac6e08fd5d0b88f67fa9a59248f60cbe8ea0843184c0", "blockindex" : 0, "blocktime" : 1405841419, "txid" : "e9524d73dfdd3db30aec6405bb2c0ec02c52b8fa88b88d7add53414da04c963d", "time" : 1405841419, "timereceived" : 1405841438 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 38.80000000, "confirmations" : 12, "generated" : true, "blockhash" : "00000000982d173024b4c1092e2521d50be3ec41ff973e90afd4d2fd2e8dfcbb", "blockindex" : 0, "blocktime" : 1405841665, "txid" : "5b684c72e6d816db0d8ff4e04b62252c4d2fe3e7e27425131fb10f5af266a487", "time" : 1405841665, "timereceived" : 1405841701 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 39.80000000, "confirmations" : 10, "generated" : true, "blockhash" : "0000000077e2f2f13bbe01ba13dea25b439a34c2335e747aa03e2024da4634f5", "blockindex" : 0, "blocktime" : 1405841713, "txid" : "dad23872b7d2e856aebc16b89bd0ec9281e423e96b0bf019fc1569a6bf169843", "time" : 1405841713, "timereceived" : 1405841731 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 37.80000000, "confirmations" : 9, "generated" : true, "blockhash" : "0000000098523f224cdcf48310e9cab0c7e45319d76764c514c0aa2ddd6098cc", "blockindex" : 0, "blocktime" : 1405841893, "txid" : "0c94ff635296a17b0b9dba1b0a125a5cada543f0b635f86bc050ce1657c8826d", "time" : 1405841893, "timereceived" : 1405841895 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 19.40000000, "confirmations" : 3, "generated" : true, "blockhash" : "000000002f0caff1c9472545c845890bb9648f62b26c63656a6d398d390599e2", "blockindex" : 0, "blocktime" : 1405842940, "txid" : "298a3a421621331c6a0c287f59bea1545da164408ff6982ff98ea02a8b1dc519", "time" : 1405842940, "timereceived" : 1405842968 } ]
Code:{ "version" : 91200, "protocolversion" : 70019, "walletversion" : 60000, "balance" : 334.40000000, "blocks" : 721, "timeoffset" : 12, "connections" : 8, "proxy" : "", "difficulty" : 2.09543239, "testnet" : true, "keypoololdest" : 1405815499, "keypoolsize" : 101, "paytxfee" : 0.00000000, "mininput" : 0.00001000, "errors" : "" }
tdrk aren't actual drk's are they?Start your wallet with "testnet=1" in darkcoin.conf
You got it - testnet is actually completely separate blockchain, the coins will never have any value.tdrk aren't actual drk's are they?
Maybe you can add this "equlto:" and "inmlist:" display from mainnet, too?
I will, and another command rank.Maybe you can add this "equlto:" and "inmlist:" display from mainnet, too?
Testnet is a separate blockchain, with distinct coins (tDRK). These coins have no value and their only purpose is for testing. You can join the current testnet by downloading one of the most recent RC4 binaries, and putting a "testnet=1" line in the darkcoin.conf. You can also use the normal miners to mine testnet coins, or join a testnet pool.I have a question.
you said:"Note: The blockchain had to be restarted, so all of you will have to collect your test darkcoin again. Although, it's really easy to collect right now, so have at it"
I have some darkcoin.So what's the "test darkcoin"?How to collect?
Evan is admin of this pool and likely sleeping now. I would suggest to create a new account or use testnet nomp pool instead.Cannot cash my coins out of the http://ec2-54-91-161-78.compute-1.amazonaws.com/ pool.
When entering pin to cash out - error saying "cannot send email to this address"
Now my account is locked. Could someone with back end access reset and email me my new pin and fix the email unlock issue.
Username: Stealth923
Thanks!
Sorry for asking this again, isnt the main net blockchain even older? Are we sure this does not create any issues?Nope, the problem was a really old block that wasn't getting accepted by CheckBlock (only on testnet)
Yep, mainnet is older, but testnet has seen more different CheckBlock() implementations and hard forks during its lifespan.Sorry for asking this again, isnt the main net blockchain even older? Are we sure this does not create any issues?
I want to help, I can throw 120mhs at amazon test pool for a while, but since thats 10x the network size i don't want to cause a problem. Advice?
Haven't merged the fix to RC4 code yet, will do after breakfast :smile:Just downloaded Mac version and it has the previous issue with the addresses font. Though you should know.
