v0.10.12.x RC4 Testing
****** PLEASE UPDATE TO 9.12.7 OR 10.12.7 *******
- Added a smart input splitting method. Place 1000+DRK into a brand new wallet and it will be split into many inputs compatible with Darksend
- DoAutodenomination now tries the correct balance (it was getting stuck on the wrong inputs)
Still gettings these errors, whereas the 10,000DRK vin was split in multiple amounts now.
2014-07-26 17:06:06 SplitUpMoney Success: tx 144a1334ee3f16606860fc491e626f507ed7923267351098717ad40428bfdd62
http://test.explorer.darkcoin.qa/tx/144a1334ee3f16606860fc491e626f507ed7923267351098717ad40428bfdd62
2014-07-26 17:15:33 found coins 13
2014-07-26 17:15:33  vin nValue 19980000000
2014-07-26 17:15:33  vin nValue 3996000000
2014-07-26 17:15:33  vin nValue 1000000
2014-07-26 17:15:34  vin nValue 3996000000
2014-07-26 17:15:34  vin nValue 1000000
2014-07-26 17:15:34  vin nValue 19980000000
2014-07-26 17:15:34 DoAutomaticDenominating : Running darksend denominate for 199 coins.
2014-07-26 17:15:34 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
BTW: GetCurrentMasterNode() returns the correct node now :)
4184 211.99.224.173:19999
4185 192.168.56.102:19999
4186 188.226.243.116:19999
4187 188.226.248.36:19999
4188 211.99.224.173:19999
4189 184.73.179.235:19999
4190 188.226.223.5:19999
4191 184.73.179.235:19999
4192 54.208.138.69:19999
4193 54.191.236.39:19999
4194 192.168.56.102:19999
4195 184.73.179.187:19999
4196 188.226.223.5:19999
I just tried to DarkSend a large amount, and got the error "unable to locate enough DarkSend denominated funds...etc... But before that I successfully DarkSent something like 156 coins (hey check it out, Evan created a new verb!)
This is on version 7, looking good :)
ubuntu@ip-172-31-18-216:~/.darkcoin$ darkcoind getinfo
  "version" : 101207,
  "protocolversion" : 70022,
  "walletversion" : 60000,
  "balance" : 32563.51940008,
  "blocks" : 4221,
  "timeoffset" : 0,
  "connections" : 2,
  "proxy" : "",
  "difficulty" : 0.10761101,
  "testnet" : true,
  "keypoololdest" : 1406001326,
  "keypoolsize" : 1001,
  "paytxfee" : 0.00000000,
  "mininput" : 0.00001000,
  "errors" : ""
ubuntu@ip-172-31-18-216:~/.darkcoin$ darkcoind masternode start
successfully started masternode
ubuntu@ip-172-31-18-216:~/.darkcoin$ darkcoind masternode list
  "54.202.29.136:19999" : 1,
  "54.208.138.69:19999" : 1,
  "54.183.79.141:19999" : 1,
  "54.92.17.170:19999" : 1,
  "211.99.224.171:19999" : 1,
  "92.222.10.179:19999" : 1,
  "54.179.187.196:19999" : 1,
  "188.226.243.116:19999" : 1,
  "211.99.224.174:19999" : 1,
  "188.226.248.36:19999" : 1,
  "211.99.224.172:19999" : 1,
  "211.99.224.173:19999" : 1,
  "188.226.223.5:19999" : 1,
  "184.73.179.148:19999" : 1,
  "184.73.179.187:19999" : 1,
  "184.73.179.196:19999" : 1,
  "184.73.179.235:19999" : 1,
  "54.191.236.39:19999" : 1,
  "192.168.56.102:19999" : 1
Updated MN to 101207. Amazon Tokyo here.
Noticed UNKNOWN STATE! warning that pops up in the Darksend Status thingy, usually after more than 2 entries have entered the denomination pool... seems to work anyway. ;)
Some minor strangeness happening at https://test.drk.mn/masternodes.html - my MN currently shown 'unlisted' except p2pool where it's shown 'current'
MN itself looks fine to me with a :1
And 209.222.30.51 has somehow managed to get mentioned three times in the masternode list:
ubuntu@ip-172-31-23-218:~/.darkcoin$ ./darkcoind masternode list
"209.222.30.51:19999" : 0,
"192.168.56.102:19999" : 1,
"209.222.30.51:19999" : 1
Same here. Looks like auto denomiation broke my masternode ( aktivated with cold wallet, maybe because the initial 1k Drk was touched )
Running v0.10.12.7 with DS+ (not a MN) appears to be causing a denominating problem with my single 1k DRK wallet. It seems to be trying to denominate 200 DRK 3 times and then it starts having errors and apparently looping. Hopefully below is enough information to see what's happening (had a bit of trouble fitting it into 10k characters). If not just let me know (may get a response faster via IRC).
Edit: These errors may not be as serious as I initially thought. Executing getbalance now returns "999.98800000". Is that the expected fee to mix 1k?
Edit: Balance now "999.84900000" which has apparently all been put in a single address of "mfuNdNYZeHytU3mBbu3eUaA1FrYNan1ubK".
$ grep -i denom debug.log
2014-07-26 20:55:28 DoAutomaticDenominating: Split up large input:
2014-07-26 21:02:31 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 21:02:31 DoAutomaticDenominating: Split up large input:
2014-07-26 21:16:34 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 21:18:34 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 21:22:27 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:22:27 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:22:48 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:22:48 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:23:06 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:23:06 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:25:25 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:25:25 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:27:43 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:27:43 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:30:21 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 21:33:33 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:33:33 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:37:20 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:37:20 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:44:11 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:44:11 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:45:57 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:45:57 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:46:39 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:46:39 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:48:04 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:48:04 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:49:57 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:49:57 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:51:10 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:51:10 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:51:29 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:51:29 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:51:35 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 21:52:22 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:52:22 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:52:52 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:52:52 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:53:09 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:53:09 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:54:13 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:54:13 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:55:19 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:55:19 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:56:11 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:56:11 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:59:56 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 21:59:56 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 22:02:56 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 22:02:56 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 22:05:21 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 22:05:21 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 22:05:26 DoAutomaticDenominating : Running darksend denominate for 200 coins.
2014-07-26 22:07:41 DoAutomaticDenominating : Running darksend denominate for 0 coins.
2014-07-26 22:07:41 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-26 21:22:27 received block 00000001b56028dac5a4d6530bd57096131fbd0152846af4c578019e31587de5 peer=10
2014-07-26 21:22:27 MasternodeConsessus - found a winner
2014-07-26 21:22:27 MasternodeConsessus - strong consessus
2014-07-26 21:22:27 MasternodeConsessus - Masternode payment to OP_DUP OP_HASH160 f0d607330cf4aff43d7c6d36600acd880dfbf4b2 OP_EQUALVERIFY OP_CHECKSIG
2014-07-26 21:22:27 Committing 30 changed transactions to coin database...
2014-07-26 21:22:27 SetBestChain: new best=00000001b56028dac5a4d6530bd57096131fbd0152846af4c578019e31587de5  height=4265  log2_work=42.552765  tx=31521  date=2014-07-26 21:22:04 progress=1.000000
2014-07-26 21:22:27  --- strUseMasternode
2014-07-26 21:22:27 CDarkSendPool::NewBlock - Disconnecting from old masternode
2014-07-26 21:22:27 CDarkSendPool::DisconnectMasterNode
2014-07-26 21:22:27 CDarkSendPool::DisconnectMasterNode -- disabled masternode
2014-07-26 21:22:27 CDarkSendPool::NewBlock - ERROR: You have existing pending payments and a new masternode was detected. You must resubmit them.CDarkSendPool::UpdateState() == 2 | 6
2014-07-26 21:22:27 found coins 1
2014-07-26 21:22:27  vin nValue 1000000
Masternode 54.191.236.39 and local qt wallet updated.
"version" : 101207,
"balance" : 6300.00660000,
"blocks" : 4139,
"timeoffset" : 0,
"connections" : 2,
"proxy" : "",
"difficulty" : 0.10486389,
"testnet" : true,
"keypoololdest" : 1406222622,
"errors" : ""
Still can't send using 'use darksend inputs only' but I can now manually select denominated inputs and send them.
edit: welcome to our four new Chinese testnet masternodes! :)
Many thanks, mate
It is very exiting to see the RC4 testing evolves every morning when I get up. Although can't help much. Im glade to take a part in the testing and stand with you guys together.
Updated to 0.10.12.7:
~$ grep denom .darkcoin/testnet3/debug.log | tail
2014-07-27 07:29:44 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-27 07:29:44 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-27 07:29:45 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-27 07:29:45 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-27 07:33:27 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-27 07:33:27 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-27 07:41:47 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-27 07:41:48 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-27 07:44:31 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-27 07:44:31 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
This is the 721 coins: http://test.explorer.darkcoin.qa/tx/04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66
I've a wallet that can't start anymore, after a few moments exits with "Floating point exception(core dumped)"
http://test.explorer.darkcoin.qa/address/miG7eUf1nVPjMYea2VXaXWwGj34NggztH1
I'm using v0.10.12.7-beta
Drop a message if anybody want to have a look at and i'll send the wallet.dat
(also have a few core dump, compressed are about 5MB each)
Hmm, I've never seen that happen. Please send me the wallet.dat and I should be able to fix it. Just shoot it over to evan@darkcoin.io
With help from vertoe, i finally got the test wallet working!
My address mw3sQzHe2Qb3H7nZxjmjHuV6cYgNJjJFMX.
I will keep the wallet online as long as i can, and post any logs that are interesting.
Cheer vertoe!
It hasn't, it's synced up, it just thinks there's more blocks than there are for some reason. Haven't noticed this behaviour myself but will keep an eye out. You can check the blockheight at http://test.explorer.darkcoin.qa/chain/DarkCoin
I have, as I jumped in late for testnet. Got me really confused for a while. Blockchain got stuck a few times (but my internet is quirky right now), stopping and starting the QT made it jump back up. Estimated blocks were way above real height, but it auto-corrects as it syncs up.
