M
MangledBlue
Guest
Can somebody point me to the 10.12.5 Win-Qt?
RC4 binaries are linux only at the moment I think.Can somebody point me to the 10.12.5 Win-Qt?
2014-07-25 03:28:37 IsDarkSend 1
2014-07-25 03:28:37 SelectCoins() best subset: 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 total 9.00
2014-07-25 03:28:37 keypool added key 1003, size=1001
2014-07-25 03:28:37 keypool reserve 3
2014-07-25 03:28:38 keypool return 3
2014-07-25 03:28:39 Flushing wallet.dat
2014-07-25 03:28:39 Flushed wallet.dat 103ms
2014-07-25 03:28:39 UPnP Port Mapping successful.
2014-07-25 03:28:45 ERROR: CTxMemPool::accept() : inputs already spent
2014-07-25 03:28:45 f2e768881da1133169206db8a544cf95b7d20e4369051820e590df2e322d08c4 from 54.191.87.83:19999 /Satoshi:0.10.12.5/ was not accepted into the memory pool
I dont think so - only the v10 RC4 binaries which are closed source will denominate for nowwill V9 denominate?
And what can I do besides mine and send/rec coins?
Just sent you 6000 tDRKHow hard is it to do what you have just done?
9.x is only interesting for pool operators.I kind of wondering what the point of the 9.xx.x builds are at this point, with DS+ coming in RC4. Just keeping an open-source option I guess.
Not working- Masternodes should change every block now
flare,
Yes, there is a modulo operator in the code, but eduffield changed it to 1 in 0.9.12.5 - so as he wrote, masternode should change every block. It seems there is a mod 10 left in the code :what:flare,
The strange thing is that the actual payee is indeed changing every block but there seems to be no correlation anymore between the "current masternode" (ip) and the actual "payee" (pubkey).
The current masternode remains the same for 10 blocks, although there has been an occurence where it was for 20 blocks (random?).
Could there be some mod 10 remaining somewhere in the code? (referring to https://darkcointalk.org/threads/rc4-testing.1830/page-17#post-13059)
Yes, i confirmed that i agree on his takeflare> That's what BelStar said, no?
Nevermind, all is good :smile:Ah ok... I am tired so you have to perdon me.![]()
Well its been a few hours and I'm not seeing anything in logs and coin control.
http://test.explorer.darkcoin.qa/address/n2ftKiN6JrHfSW16PCoLUWXbe8vm5CvfmG
Masternode=0
Also, blockchain getting stuck frequently, but I think the problem is my end. Stopping/restarting goes up to height instantly
