You cant denominate 1000 DRK in one go. 2 rounds does not mean 2 transactions of denominating but 2 full rounds of mixing for each coin/input.i'm testing a 1000 drk from the test faucet sent to my new wallet (10.12.27) and i'm getting a bit curious how these Darksend Denominates exactly work.
Wallet is set on default settings (2 rounds / 1000 amount drk to keep anonymized) and after 90 minutes i already have 3 payments to myself (each 0.001 drk)
and 13 Darksend Denominate's (each 0.001) and its still on Darksend Round 1 and keeps denominating ? I see the same high amount of Darksend Denominate
transactions on mainnet (some users posted pics) so i'm wondering why exactly it needs that many Darksend Denominate's ?
okay, thought i checked because in previous test updates the Darksend Denominates were a lot less in my wallet and it all went a lot faster so i wasnt sure if this was intended or not.
Maybe Evan simplified the denomination process in previous test updates so i was used to seeing less Darksend Denominate transactions or something.
try to set rounds to 1 (in options) and wait for transactions to confirm, that should workStarting to get a little worried here.
It's been an hour and a half and I have 4 unconfirmed transactions at 0.001
A lot of my coins were locked so I right clicked and unlocked them in coin-control
nothing happen
It continues to show
1.1752075DRK Total Bal
ZERO-DRK Anon
67.00000013DRK unconfirmed
I exited the Cli and when it came back up
no change in the above - but
now when I go into coin-control
it only shows that I have 1.1752075DRK
Are my coins lost?
Is there a cmd-line I can input?
Re-load the Blockchain?
ugh - I so need Evan to hold my hand right now...... tell me it's going to be okay?
.....help
EDIT: coin control doesn't show unconfirmed inputs, that's ok
I've been running .27 in testnet since it's released and it can't finish second round till now, just keep denominating in never ending loop. So I changed rounds to 1 and waited for transactions to confirm and finally got "no funds needed to denominate" (or smth like that) in debug.log. So I guess that method should work in mainet too. I hope so.:wink:Good to know
- I did set it to 1
I've been lurking the forums
but nothing happens
- I can chill all night
I just do not recall this happening in testnet
and now it's the last of my DRK outside of the MN coins
I saved the debug just in case
You think I'd be ok running on Prop's P2P and have coins coming in?
Ok... Windows wallet v.27... I started with a fresh wallet, with Options in Settings: 1 DS round to use, Amount of Darkcoins to keep anonymized: 1000. Got 2000 tdrk from faucet.
Within minutes the wallet got 1 DS denominate and 1 Payment to yourself, and 999 DRK got anonymized pretty fast. I'm not sure what makes this version run differently this time but probably because of the option to set Darksend Rounds to Use = 1 .
Yeah, pretty sure that rounds >1 is bugged.
is the ''rounds >1 bugged'' only bugged in testnet ? maybe the v10.12.27 cannot be tested on testnet because the test MN are not updated to v10.12.27
or something ? I will do some more testing on testnet tonight after work, i would really like it to work with 2 rounds on testnet first before switching to mainnet myself.
