Reuben's Start Multiple Masternodes from One Wallet Guide (start-many)
This is how my remote dash.conf looks like on two masternodes on the same server:
Masternode 1
rpcuser=xxxxx
rpcpassword=xxxxxx
rpcallowip=127.0.0.1
masternodeaddr=my external ip:9999
bind=127.0.0.2
bind=my external ip
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=200
# change ami_public_ip to public ip address which you connected by ssh
externalip=my external ip
masternode=1
addnode=23.23.186.131
masternodeprivkey=xxxxxxxxxxxxxxxxxxxxxxxxxx
Masternode 2
rpcuser=xxxxxxxxxxxxxx
rpcpassword=xxxxxxxxxx
rpcport=8003
bind=127.0.0.4
bind=my external ip
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=200
masternode=1
masternodeprivkey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I have 2 mns running on the same server, using 2 separate ips. I used a similar config to yours. When i issue start-many i get the confirmation the both are running, and withing 5 minutes i can also verify that both IPs are up. However while later, one of them goes down for no apparent reason.
Any ideas to help me out with this? Here's my dash.conf on the server:
rpcuser=xxxxx
rpcpassword=xxxxxx
bind=127.0.0.1
bind=external ip1
masternodeaddr=external ip1:9999
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=256
masternode=1
masternodeprivkey=XXXXXXXXXprivkey1
rpcuser=xxxxx (same user as above mn)
rpcpassword=xxxxxx (same password as above)
bind=127.0.0.2
bind=external ip2
masternodeaddr=external ip2:9999
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=256
masternode=1
masternodeprivkey=privkey2
"bind"= <your_external_ip1> and "bind"= <your_external_ip2>. Remove those bind=127.0.0.x lines.
And, you have to set "rpcport" to 2 different ports because when both dashd try to open a RPC-socket on 127.0.0.1 one will fail.
Ugh, removed the bind=127.0.0.x part, but im not sure where to put the different ports for rpc.
Wild guess is rpcallowip=127.0.0.1:porthere?
Problem is I dont know which port to use
use different for each dash.conf
port=9998
port=9997
etc....
edit: I meant what is in the bottom ;)
actually
rpcport=9998
rpcport=9997
etc
:rolleyes:
But why does he have to do all this? Can't he just have these lines for all of his MNs in one wallet and it still works on Mainnet: (omit the line numbers)
  1. rpcuser=SomeRandomString
  2. rpcpassword=EvenLongerRandomString
  3. rpcallowip=127.0.0.1
  4. listen=0
  5. server=1
  6. daemon=1
  7. logtimestamps=1
Update: I tried setting port to a diff value, then i tried setting rpcport to a different value. Same result, one of the two masternodes goes down after a few minutes. Does anyone know if I can start the daemon to only log errors and not all mn debug messages? At least that way i can find out what s going on
  4. listen=0
  5. server=1
  6. daemon=1
  7. logtimestamps=1
..... Here's my dash.conf on the server:
:rolleyes:
Send me debug.log files from both datadir-s on your server pls. I'll have a look. [email protected]
:rolleyes:
UdjinM6, you the man! Alas, feeling a bit idiotic, now that u mention it, i have to ask...both data dirs?? I have not seen any mention anywhere that there should be TWO data dirs. I only had one, 1 config file with the concatenated content u see above.
Sigh, i wish these things would be more explicit.
I will try and run 2 daemons with 2 configs, see how that works
Aha! Yep, that's the problem.
You need 2 datadirs with separate dash.conf in each one and ran daemons like
dashd -datadir=/full/path/to/datadir1
dashd -datadir=/full/path/to/datadir2
Hi there,
Could someone point me what else can I check - mainly - I'm able to start-many two of my masternodes:
"overall" : "Successfully started 2 masternodes, failed to start 0, total 2",
"detail" : {
"status" : {
"alias" : "MN1",
"result" : "successful"
"status" : {
"alias" : "MN2",
I can see them on dashninja.pl, but as soon as I turn off my cold wallet the masternodes disappear :-(
dash.conf on remote servers:
rpcuser=A93Aap5Nr80OS543OJQWoJWYcWoMFt2njKbBiUnzA34YEocBfegGrOiHBfpgX8mFSKmOJsej
rpcpassword=KGFU9nQ3GY43hIeKWRmXPexXtlvimaM2CprehLhiRBsSi3JHj5Zot2lHbMZZNJOz3oiltTh0J
#rpcallowip=127.0.0.1
listen=1
server=1
daemon=1
logtimestamps=1
rpcuser=A93AaC93jncL0iWCPb32maRHdxfZNUyb6Ejl1fPfrY4CA2nf25Z5Q45qfL7nT12lqywujsLLQsB0SEocBf
rpcpassword=KGFU9nQGYhIeKWRmXPexX4el61Ke1lA981Ncrc8RFjxySVwZdvfSXEqebMZZNJOz3oiltTh0J
listen=1
server=1
daemon=1
logtimestamps=1
masternode.conf and dash.conf on local (cold wallet):
MN1 IPaddress1:9999 MASTERNODEPRIVKEY TRANSACTIONHASH 0
MN2 IPaddress2:9999 MASTERNODEPRIVKEY TRANSACTIONHASH 1
rpcuser=R12AqewN43DOrewMFN2f4U32fM432fB2Ef32fR2fS2fA2fN2fD43fL4gt65Eh76Tj76Tj76EuR65yS54
rpcpassword=LgfdsO3214NfeGttgE54fsdfsdg5g335Rgg6R45gA45gN5Dg5OgM54gS5gT5Rg5Ig5NgG5gO5Fg5
listen=0
server=1
daemon=1
logtimestamps=1
Am I missing something??
Dash version - "version" : 120049,
Best regards
dash version @ local ? same or lower?
For local you only need the masternode.conf file and put there this:
alias_of_MN IP:9999 generated_privkey TX_ID INDEX_NR
On remote config - dash.conf put these:
rpcuser=
rpcpassword=
rpcallowip=127.0.01
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=100
masternode=1
masternodeprivkey=same_privkey_as_for_local_config
start from local and tell me if it disappears now....
Thank for a quick reply.
In first post I see - "Please note that when using masternode.conf, dash.conf no longer needs to specify "masternode=1, masternodeprivkey and ip" anymore as this is all integrated into masternode.conf."
Dash version - remote and local = newest 0.12.49
Had to add masternodeprivkey also. Testing :)
you do not need to put masternode=1 on local..... your local needs only one line in config ....
in your remote, YES, you need to have the code above....
edit: to clarify the things....
on local you needs only masternode.conf
on remote you needs only dash.conf :)
I understand now.
Well, at least now I see "EnableHotColdMasterNode() - Enabled! You may shut down the cold daemon." on remote debug.log's :)
Looks good :) Switched off cold wallet and I still see my MN's on dashninja.pl :)
Thanks a lot Spławik :) (dzięki bardzo Kolego :)
Hi guys,
I have a problem here.
Local dash.conf = empty
Local masternode.conf entries are correct.
It always says
you must set masternode=1 in the configuration
(code -1)
when starting the nodes from console.
But when I add that to dash.conf it also wants a mnprvkey there..
What am I doing wrong?
