Thank you so much for letting me know
Unless you move your coins or go offline for more than an hour you place in the queue should be the same.Can anyone explain to me what the effect is of issueing a start-alias / start-many on the eligibility for a masternode payment? Will it put the masternode in the back of the line or will it stay in place as it was before issueing the command?
Make sure you have port 9999 in inbound rules for security group of your ec2 instance and also that it's "anywhere" in "source" column.I've been stuck for some time (over 2 days) when I tried to donate with one masternode, it all worked out. It's a non- amazon server. Then I tried my amazon server, and I got a terrible pose score. This might have been caused by accidentally mixing up my genkeys / conf files. So I got a new IP address and new genkey and now my wallet is even worse, getting a score of up to 12 (whereas before it was only 5 or 6) I also get this error when I try to start dashd, actually dashd starts even so I get this error:
Unable to bind to myexternal:9999 on this computer (bind returned error Cannot assign requested address (99))
I suspect it has somethnig to do with amazon, but I have no idea. I have the config file set up as shown on page 2 of this thread. Does that error give anyone a hint as to where I should start trying to fix this? Thanks! I appreciate any help![]()
Should be no hard limit afaikOne more question:
How many nodes can you install and work from the same wallet? It is unlimited?
Thanks for your kind responses. This forums are really helpful
Not max 1001 addresses??? As the keypool during the loading new wallet.dat??Should be no hard limit afaik
I guess we can even have 10,000 masternodes on a same wallet if we create a 10000 keypool wallet:Not max 1001 addresses??? As the keypool during the loading new wallet.dat??
Nope, keypool is a pool of newly generated but yet unused addresses available for your even if your wallet is locked so 1) you can request 1000 "new" addresses without unlocking your wallet and 2) when you backup your wallet you already have 1000 change (or whatever you use them for) addresses and can recover them in case something goes wrong. So it basically gives you some gap in time when you can feel more or less safe.Not max 1001 addresses??? As the keypool during the loading new wallet.dat??
It actually displays the line itself and not the line number (and that could be confusing, I see it now). However it should ignore empty lines... Make sure there is no space on the last line etcI followed Reuben's guide to start-many and set up 10 masternodes on Testnet and they were started successfully. Then I added 10 more MNs to the wallet. When I tried to start the wallet I got the error "Could not parse masternode.conf line:", but it does not tell which line.
I then took out the 10 new MNs, save masternode.conf, and tried to restart again, but it still says the same error... I've checked, everything is still intact, no space in between the lines... Could someone tell me what is wrong here? Thank you.
EDIT: Each line is all in one line, my screen is not wide enough, same with the forum screen is not wide enough.
I was afraid you were going to tell me that because i use Notepad.. lol...It actually displays the line itself and not the line number (and that could be confusing, I see it now). However it should ignore empty lines... Make sure there is no space on the last line etc
Well, I suppose that you might have another line after MN10 and it contains spaces i.e. " "I was afraid you were going to tell me that because i use Notepad.. lol...
What do you mean "Make sure there is no space on the last line" ?
All I did was .. I put the cursor after the last index of the last line and kept pressing "Delete" several times, and now the wallet is starting... Why does it have to be like this?Well, I suppose that you might have another line after MN10 and it contains spaces i.e. " "
If that's not the case I would prefer to have text and not the picture :tongue: - use code tag here and paste masternode.conf contents exactly as it is (i.e. ctrl+a, copy, paste inside code tag)
It doesn't butAll I did was .. I put the cursor after the last index of the last line and kept pressing "Delete" several times, and now the wallet is starting... Why does it have to be like this?![]()
