mr.slaveg
Active member
I made a correction on Github.
https://github.com/darkcoin/p2pool-drk/pull/
UdjinM6, you can accept the changes?
Nope, I'm not maintaining it. I guess eduffield does.I made a correction on Github.
darkcoinproject on github is Evan's original account there and I hope he still maintains it too. So if there are some changes to xcoin-hash you can push them there.Repository xcoin-hash is not updated since inception (10 months). And belongs darkcoinproject development. I thought that doing a common cause and combine sources in a single repository would be nice. If it's a bad idea, then I will remove them.
Cool are you running this repository? Could you create a pull against https://github.com/vertoe/p2pool-drk ?
Most recent python modules hereRepository xcoin-hash is not updated since inception (10 months). And belongs darkcoinproject development. I thought that doing a common cause and combine sources in a single repository would be nice. If it's a bad idea, then I will remove them.
Hi! I created commit to github. Check please.Cool are you running this repository? Could you create a pull against https://github.com/vertoe/p2pool-drk ?
Merged thanks.Hi! I created commit to github. Check please.
merged thanks.Vertoe, please merge it.
thanks for your help. do you have a miner available and can confirm both mainnet and testnet are working?Branch on a bitbucket.org longer not supported!
The current version p2pool-drk on github.
Thanks for helping out, will send you some tips. 60243169e3613fb00491edb4635a5ebc30f0d17a250e12b97fe71cea0b1283d3From the main pool all good))
http://drkpool.hopto.org:7903/
A darksend transaction http://explorer.darkcoin.fr/tx/60243169e3613fb00491edb4635a5ebc30f0d17a250e12b97fe71cea0b1283d3Vertoe, what's this "60243169e3613fb00491edb4635a5ebc30f0d17a250e12b97fe71cea0b1283d3"?
