tryThanks! Can I disable logging p2pool? I have a SSD drive, I want to disable the log
--logfile /dev/null
@tungfa
Agree to update this OP,
I believe that the official p2pool source is https://github.com/dashpay/p2pool-dash
The list of p2pool node online is already in wiki.
IMO, 20 kH/s is too low to get any share so it's possibly unable to be calculated on Mainnet.Hi! I am trying to create my own pool and all is set and done. Though the miners are creating around 20 kH/s, why do I always get this message:
Local: 0H/s in last 0.0 seconds Local dead on arrival: ??? Expected time to share: ???
Any help is appreciated.
Thanks for the possible explanation. What's the minimum hash should I calculate so that the statistics shows correctly? Current Pool Rate is 540GH/s (12% DOA+orphan).IMO, 20 kH/s is too low to get any share so it's possibly unable to be calculated on Mainnet.
540GH/s is about 540,000,000kH/sThanks for the possible explanation. What's the minimum hash should I calculate so that the statistics shows correctly? Current Pool Rate is 540GH/s (12% DOA+orphan).
Thank you @thelazier I will run p2pool on Testnet now. Please consider me a novice while answering my following question:540GH/s is about 540,000,000kH/s
So, please try run p2pool on Testnet to check whether your setup have same problem or not. Testnet global pool hash rate is about 16MH/s (about 16,000kH/s).
The pool's local hash rate usually be calculated from valid shares submit from miners if your miners doesn't submit any valid shares the pool's local hash rate would show 0.Thank you @thelazier I will run p2pool on Testnet now. Please consider me a novice while answering my following question:
The Local rate in p2pool is the local hash rate that is being generated by the miners on my pool (I have 5, so 5x25 = 125 kH/s). If I want to display this on the Local rate, how can I do that? Will that be wrong?
