I would guess your are on ubuntu 14.04 and not 16.04invoke-rc.d: unknown initscript, /etc/init.d/netfilter-persistent not found.
What should I see when I execute the iptables command below? I saved the rules you posted above.
iptables -L
The default behaviour for the INPUT chain is ACCEPT, which, at the end is redundantly repeated by the rule -A INPUT -i eth0 -p tcp -j ACCEPT
Basic invalid TCP packets are blocked, but you can still reach any other socket listening to the interface eth0 on any port. You can also flood any port other than 9999, which may cause a ton of half open connections on the host.
Also, I think this part, causing a jump to LOGNDROP will never be reached:
-A INPUT -j LOGNDROP
Why? Because A INPUT -i eth0 -p tcp -j ACCEPT at the end accepts any TCP packet on eth0 not matched by any rules above, and thus leaving the chain (if matched) and proceeding to the other tables (nat, etc.).
I would like to suggest, that you test your configuration before you simply trust a copy&paste solution.
...you will get, as before, immediately spammed with invalid connection attempts or garbage data up to the connection limit of the dashd
Crap yeah that's on me, I was modifying my original script by adding chaeplins better ddos rules and missed that. Removed the line.
despite i had the requested hardware Dual Core CPU and 2 GB Ram i was kicked from the masternode list and lost 2 dash that i needed to get now !
Moving to Vultr $20 Quad CPU and 4GB RAM
Hey Figl, do you recommend setting a low maxconnections setting in dash.conf or high? I have it on maxconnections=64 and some of my nodes went down even with good specs. Maybe better to set a lower value? Thanks for spreading the knowledge![]()
Sorry to bother you again, but I checked your rules once again and stumbled upon the first rules:
-A INPUT -p udp -j REJECT --reject-with icmp-port-unreachable
-A INPUT -p tcp -j REJECT --reject-with tcp-reset
-A INPUT -j REJECT --reject-with icmp-proto-unreachable
It's already late here in central Europe, I'm dead tired and I might be wrong. But aren't those lines instantaneously rejecting any kind of UDP packets, followed by TCP packets, and finally rejecting ALL packets with a protocol unreachable icmp packet - thus effectively preventing all kinds of connections?!
I think the next line over-ruled that for connections on 9999, which seemed confirmed since my nodes are active and getting payed. Unless mine are now an example of lazy masternodes, I am changing the rules on one of my nodes and will monitor the cpu usage.
Correct me if 'm wrong, but already established connections should not be affected because of -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT before the mentioned lines, which may include existing masternode connections. At least as I understand it, you should not be able to establish any kind of (new) connection to a server using that iptables configuration. Did you try to SSH (new connection) into a server using that iptables config?
Maybe I'm failing to see something obvious and maybe I'm totally wrong. Will check back later, after some sleep![]()
For those less technologically savvey there are step by step instructions below for Ubuntu 16.04. If you followed TAO's set up guide this will work for you.
Enter root and enter the following commands
******* First Remove ufw
sudo ufw disable
sudo apt-get -y remove ufw
sudo apt-get -y purge ufw
****** Now install persistant ip tables and say yes when the purple screen appears
apt-get install -y iptables-persistent
invoke-rc.d netfilter-persistent save
service netfilter-persistent stop
service netfilter-persistent start
***** Now remove the old iptables file and paste in the new rules
rm /etc/iptables/rules.v4
joe /etc/iptables/rules.v4
************** Now paste in these rules and save, Note- change port 22 if you moved ssh to another port.
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:LOGNDROP - [0:0]
:OUTPUT ACCEPT [0:0]
-A INPUT -i lo -j ACCEPT
-A INPUT -m conntrack --ctstate INVALID -j DROP
-A INPUT -p tcp -m tcp --dport 9999 -j ACCEPT
# some tcp ddos
-A INPUT -i eth0 -p tcp -f -m tcp -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,ACK -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,PSH,ACK,URG -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 0 -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9998 -j REJECT --reject-with tcp-reset
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 8 --connlimit-mask 24 --connlimit-saddr -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 2 --connlimit-mask 32 --connlimit-saddr -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -m conntrack --ctstate NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -m conntrack --ctstate NEW -m recent --update --seconds 30 --hitcount 3 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -i eth0 -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --update --seconds 30 --hitcount 3 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -j ACCEPT
-A FORWARD -j REJECT --reject-with icmp-host-prohibited
-A LOGNDROP -p tcp -m limit --limit 32/min -j LOG --log-prefix "Denied TCP: " --log-level 7
-A LOGNDROP -p udp -m limit --limit 32/min -j LOG --log-prefix "Denied UDP: " --log-level 7
-A LOGNDROP -p icmp -m limit --limit 32/min -j LOG --log-prefix "Denied ICMP: " --log-level 7
-A LOGNDROP -j DROP
COMMIT
#Remember to leave an extra space at the bottom
******* and save, then to check it is working
iptables -L
hi,
i try to set the iptables following tease intructions:
but
returns error
Did I miss something?
Are you on Ubuntu 16.04 or 14.04?
DDoSCoin
DDoSCoin is a conceptual cryptocurrency with an "evil" proof-of-work. Rather than use a hash-based proof-of-work like Bitcoin, DDoSCoin allows miners to prove that they have contributed to a Distributed Denial of Service (DDoS) against a specific target.
This. MNs should be Fort Knox, not Best Buy.I am more a supporter of a whitelisting approach. In my opinion it would be better to DROP by default, and only ACCEPT if the right conditions are met. You will then have to explicitly allow traffic to the services (without locking yourself out of course).
