Dash4Ever
Active member
Dash4Ever which VPS provider is this? pricing is better than vultr.
It was https://www.vpscheap.net/
Never had any issue with them under my 3 years of masternoding, and quick and fast support.
invoke-rc.d: unknown initscript, /etc/init.d/netfilter-persistent not found.invoke-rc.d netfilter-persistent save
Does Vultr's DDOS protection ($10 extra per month) help with these kind of DDOS attacks?
I'm a little curious, did they handpicked some IP addresses to attack? or all 4176 ip?
Some serious amount of computer power there.
In any case this demonstrates the strength of the Dash networkthey failade hard.
https://www.google.gr/search?q=Proof+of+bandwidthThe attack was against all MNs as far as we know, from 2,000 individual IPs mostly in Asia, i.e. a botnet
What exactly happens when a server is DDoS'ed? Does it just crash and restart? If that's the case, if i have my VPS set up with auto restart of dashd upon crash with dashcentral will the problem automatically solve itself if i get DDoS'ed?
this DDoS attack seem to focus on just port 9999, maybe if we all choose different ports instead of the default port this type of attack could be mitigated in the future ?It won't be able to answer any request from other peers/masternodes, so after a while it'll disappear form the masternode list due inactivity.
A possible crash is just the extra bonus you might get.
I just watched a youtube video published on 6 March where Fluffypony from Monereo talks to Tone Vays about a DDoS attack on DASH.The attack was against all MNs as far as we know, from 2,000 individual IPs mostly in Asia, i.e. a botnet
i hope this does not mean we end up having to thank fluffypony for accelerating our hardware upgrade processI just watched a youtube video published on 6 March where Fluffypony from Monereo talks to Tone Vays about a DDoS attack on DASH.
I think its great. The fluffster has in a way joined the dash development team by helping us test the network.i hope this does not mean we end up having to thank fluffypony for accelerating our hardware upgrade process![]()
This wouldn't help in the slightest, since every node (and hence everyone) would still have a list of all masternodes and ports.this DDoS attack seem to focus on just port 9999, maybe if we all choose different ports instead of the default port this type of attack could be mitigated in the future ?
For those less technologically savvey there are step by step instructions below for Ubuntu 16.04. If you followed TAO's set up guide this will work for you.
Enter root and enter the following commands
******* First Remove ufw
sudo ufw disable
sudo apt-get -y remove ufw
sudo apt-get -y purge ufw
****** Now install persistant ip tables and say yes when the purple screen appears
apt-get install -y iptables-persistent
service netfilter-persistent stop
service netfilter-persistent start
***** Now remove the old iptables file and paste in the new rules
rm /etc/iptables/rules.v4
joe /etc/iptables/rules.v4
************** Now paste in these rules and save
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:LOGNDROP - [0:0]
:OUTPUT ACCEPT [0:0]
-A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -m conntrack --ctstate INVALID -j DROP
-A INPUT -p udp -j REJECT --reject-with icmp-port-unreachable
-A INPUT -p tcp -j REJECT --reject-with tcp-reset
-A INPUT -j REJECT --reject-with icmp-proto-unreachable
# some tcp ddos
-A INPUT -i eth0 -p tcp -f -m tcp -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,ACK -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,PSH,ACK,URG -j DROP
-A INPUT -i eth0 -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 0 -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9998 -j REJECT --reject-with tcp-reset
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 8 --connlimit-mask 24 --connlimit-saddr -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 2 --connlimit-mask 32 --connlimit-saddr -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -m conntrack --ctstate NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -m conntrack --ctstate NEW -m recent --update --seconds 30 --hitcount 3 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -i eth0 -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --update --seconds 30 --hitcount 3 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 -j ACCEPT
-A INPUT -i eth0 -p tcp -j ACCEPT
-A OUTPUT -o eth0 -j ACCEPT
-A FORWARD -j REJECT --reject-with icmp-host-prohibited
-A INPUT -j LOGNDROP
-A LOGNDROP -p tcp -m limit --limit 32/min -j LOG --log-prefix "Denied TCP: " --log-level 7
-A LOGNDROP -p udp -m limit --limit 32/min -j LOG --log-prefix "Denied UDP: " --log-level 7
-A LOGNDROP -p icmp -m limit --limit 32/min -j LOG --log-prefix "Denied ICMP: " --log-level 7
-A LOGNDROP -j DROP
COMMIT
#Remember to leave an extra space at the bottom
******* and save, then to check it is working
iptables -L
Viola
Edit- Credit to chaeplin for the far superior rules
Ah i see. Is there a way to make it reboot automatically if all system resources are suddenly being used up?
Is it likely that the attacker would immediately start DDoS'ing the server again after that reboot? Of course ufw or iptables is the better option - But it would be nice to know the server would just reboot and start dashd again, should an attack slip through
:INPUT ACCEPT [0:0]
:LOGNDROP - [0:0]
