B
buster
Guest
After you delete the peers.dat file, you download the new one from here, http://drk.poolhash.org/files/peers.dat - (when you download it make sure you know where you can find it, like your desktop or whatever). Find the new file you just downloaded, it should be called peers.dat, drag and drop the file into the folder that was holding your original peers.dat.Hi. I know how to delete the old peers.dat file, but how do i replace it with the new peers.dat?
tx
