Outgoing port tester
This server listens on all TCP ports, allowing you to test any outbound TCP port.
You have reached this page on port 9999.
Your network allows you to use this port. (Assuming that your network is not doing advanced traffic filtering.)
Network service: unknown
Your outgoing IP: ~~~
Already hardcoded.Chaeplin - Is it possible to hardcode seed nodes into wallet? This problem is coming up a lot over the last few days.
Propulsion, I'm sorry, this is probably a stupid question, but where in the directory/which directory or sub folder do you paste the file once you've copied it? I'm not the most computer-literate person...
C:\Users\Your User Name\AppData\Roaming\DarkCoin\wallet.dat
Okay found wallet.dat but windows cant open it. What should i do now?
-this would not be a big deal but i dont want to keep all of my darkcoins on the exchanges. But wallet wont sink!!
-addnode=<ip> Add a node to connect to and attempt to keep the connection open
-seednode=<ip> Connect to a node to retrieve peer addresses, and disconnect
So,
create a darkcoin.conf file in note and put:
-addnode=<ip>
-seednode=<ip>
and this is all to put in?
seednode=23.23.186.131
seednode=50.16.206.102
seednode=50.19.116.123
seednode=98.165.130.67
seednode=23.21.204.34
seednode=188.142.39.105
seednode=54.248.227.151
seednode=42.121.58.91
seednode=50.81.192.39
seednode=5.254.96.3
seednode=175.115.201.44
Seems many are asking.
First download the latest wallet: https://darkcointalk.org/threads/postponing-masternode-payments-till-may-25th.578/
Find your directory for Darkcoin (In Windows usually under Users, your account, App Data and Roaming. For some you may need to show hidden folders to find it). Delete the peers.dat file and then replace with this http://drk.poolhash.org/files/peers.dat
Open Notepad, enter the following:
addnode=23.23.186.131
addnode=50.16.206.102
addnode=50.19.116.123
addnode=98.165.130.67
addnode=23.21.204.34
addnode=188.142.39.105
addnode=54.248.227.151
addnode=42.121.58.91
addnode=50.81.192.39
addnode=5.254.96.3
addnode=175.115.201.44
Safe the file as a .conf file (note as a .conf.text file...if you need help on that let me know).
Reload the wallet and you should be syncing within a few minutes.
put
Code:seednode=23.23.186.131 seednode=50.16.206.102 seednode=50.19.116.123 seednode=98.165.130.67 seednode=23.21.204.34 seednode=188.142.39.105 seednode=54.248.227.151 seednode=42.121.58.91 seednode=50.81.192.39 seednode=5.254.96.3 seednode=175.115.201.44
I replaced the perrs.dat file and created a text with all the addnode you have listed (right click, new, text document, saved as darkcoin.config
still not working, (no block source available)
