stan.distortion
Awesome progress!
Cheers, getting there anyway
The entire tab is a class so it should be straight forward to re-use, will try and get to the others so that rpcconsole can go back to being an rpc console again. Its not going through clientmodel at the mo and isn't using the proposal objects, just parsing them into its own table in the same way as the terminal commands, any thoughts on what would be best to do there? Also, any thoughts on chart logging to a DB? I'd like to put in options to add things like node count, hash rate, etc. and log it, I was thinking csv for exporting but would like it to fit in with existing methods.
