So far this is pretty cool! I'm impressed. Very easy to use.
I'm sorry, testnet is getting wiped too often and there were misunderstandings whether network is up or halted, so dashmate still on previous genesis. I will update this tomorrow as wellOn testnet, Dashmate Status shows Platform Block Height as 0, even though everything seems to be running correctly.
https://platform-explorer.com/blocks shows over 3000 blocks. Do I have something configured wrong or is it normal for that to report 0 blocks?
npm WARN EBADENGINE Unsupported engine {
npm WARN EBADENGINE package: '[email protected]',
npm WARN EBADENGINE required: { node: '>=18' },
npm WARN EBADENGINE current: { node: 'v16.20.1', npm: '9.8.1' }
npm WARN EBADENGINE }
npm WARN EBADENGINE package: '@yarnpkg/[email protected]',
npm WARN EBADENGINE required: { node: '>=18.12.0' },
npm notice
npm notice New major version of npm available! 9.8.1 -> 10.2.4
npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.4
npm notice Run npm install -g [email protected] to update!
(node:711981) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
CompileError: WebAssembly.Module(): Compiling function #331:"memchr::arch::wasm32::simd128:: packedpair::Find..." failed: Wasm SIMD unsupported @+1956688
You can see that this message is not a error but a warning and you should not have been updating a Node.js at all in the first place.npm WARN EBADENGINE Unsupported engine {
nvm install 18
nvm use 18
But I rolled out a release candidate build for your, so you can proceed with Core v20 masternode updates. I tested this release locally and on the PE testnet fullnode, my node was able to sync up and shows correct image versions.
Ok, then I will try to reproduce your issue@pshenmic
unfortunetely still pretty much the same error :
CompileError: WebAssembly.Module(): Compiling function #332:"memchr::arch::wasm32::simd128:ackedpair::Find..." failed: Wasm SIMD unsupported @+1951319
Node.JS version 20.9.0
you mean this ?Ok, then I will try to reproduce your issue
You mentioned that your have Ubuntu 20.04, what is your OS arch?
Just published a new build that fixes two bugs found by the community. @qwizzie kindly check this build out, I hope it will resolve your issue
Dash Platform v0.25.16-rc.2
* Bugfix: incorrect imports caused `dashmate setup` and `dashmate update` to crash
To update, donwnload a new .deb package, or `npm install -g [email protected]`
dashmate core cli masternodelist evo
dashmate core cli protx info protxhashblahblahblah
