make sure you use correct format address0.11.2.13 Windows build:
DonationPercent from masternode.conf when I do "masternode list-conf" is always loaded as 100 whichever value I put there (tried for ex "5", "0.05", "0,05" and "5%").
Icon in taskbar is now correct, 16x16 icon in the windows bar (just upside of "File" menu) is still wrong.
******************** TESTNET : 11.2.14 - All Users *********************************
Is masternode blinding being tested too?
git blame v0.11.2.13 src/darksend.cpp | grep blind
79e50f81 (Evan Duffield 2015-03-20 08:47:19 -0700 648) //automatically downgrade for 11.2, blinding will be supported in 11.3/12.0
Is the "Open configuration file" supposed to be working? I just tried it on the newest version, and it's not working still?
Config is not opening because the client cannot find it. I just updated my software and it opens the client just fine. The dash.conf file should exist in the same directory as dash-qt.exe, and the wallet calls notepad.exe to open the config file.Is the "Open configuration file" supposed to be working? I just tried it on the newest version, and it's not working still?
the-baker, what happens, won't open? Won't download???
But I still get the layout problems I posted earlier (a couple of releases ago). How does bug tracking work? I'd like to open a ticket for that, but Jira doesn't seem to be in use any more.
What new, source english is from Mar 12th?The translation which broke your layout had a line-break (which it shouldn't) and is already fixed over at Transifex, but those new translations are not yet used in the current builds.
