Ok, so I'm on 11.1.3 now, is that the latest? Also the lonecrouton, what is instantX depth?
Just IX'd you some tDRK with instantxdepth=33, let us know how soon you can spend it.
You can start the wallet with, eg. './darkcoin-qt -instantxdepth=23' and it will (in theory) lock the tx for 23 blocks. I think.Ok, so I'm on 11.1.3 now, is that the latest? Also the lonecrouton, what is instantX depth?
Hmm, that's not 33 blocks... looks like 6. Maybe the instanttxdepth switch isn't fully functional yet? Or I just don't understand it.
could someone plase send few 10 tDARK with IX to:
y2wLS8cqAkyjkSR3Cfiy1ezWbQzJkTmzmX
Thanks!
It's a known issue, will be fixed soon (hope so, I'm testing a fix right now). As for now, just run wallet with -zapwallettxes to clear conflicted.What does status "conflicted" mean please? I just tried to send 10 to hashcow, but don't think it went through?
Wait, weird.... I have two layers of transactions. Below they have green check marks, and that includes the funds I sent to hashcow. Then above a duplicate list of things with a | line or something where either a checkmark usually goes or the ? or clock. Here it says transaction was conflicted.
What is that?
Info: I am denominating funds as I sent the last one. Are these my fees? Why are they separated like that?
Um.... InstantX isn't being tested on mainnet...Btw, instantX on mainnet results in the transaction having trouble getting broadcast but is confirmed eventually,it takes 10-15 mins.
Ok, thanks. I'm sorry if I'm regurgitating known issues, I just haven't got the time to keep up with the whole threadIt's a known issue, will be fixed soon (hope so, I'm testing a fix right now). As for now, just run wallet with -zapwallettxes to clear conflicted.
2015-02-03 16:00:35 DoAutomaticDenominating: MakeCollateralAmounts: nSplitBalance -24421244200 nTotalBalance 75558715800
2015-02-03 16:00:35 keypool reserve 1820
2015-02-03 16:00:35 MakeCollateralAmounts: Not enough balance to split
2015-02-03 16:00:35 keypool return 1820
2015-02-03 16:00:37 Darksend is idle
2015-02-03 16:01:12 DoAutomaticDenominating: MakeCollateralAmounts: nSplitBalance -24421244200 nTotalBalance 75558715800
2015-02-03 16:01:12 keypool reserve 1820
2015-02-03 16:01:12 MakeCollateralAmounts: Not enough balance to split
2015-02-03 16:01:12 keypool return 1820
mine just finished loading again and my conflicted are gone. However, I'm sure it didn't solve the problem for future transactions. Did your old conflicted notes remain, or are you saying your transaction list cleaned up but when you sent again, you got more conflicted transactions? This is apparently being worked on, so I don't think it'll be fixed until the next release?The second wallet has also an issue with DS 1000/16R.
It stucked at 55% with insufficient funds error.
I stopped DS, closed the wallet, deleted the peers.dat and started it again with -zapwallettxes, because there was and conflicted denom tx, but didn't fix it.
Wanted to test it anyway, to know if its breakable with current versions and it doesn't appear so :grin:Um.... InstantX isn't being tested on mainnet...
I'm sorry to ask this again, but this is what I see when I do an instant transaction. I want to know if it went through instantly, or if it's not working. The big issue for me here, is that there is no visual confirmation that tells me it's been accepted instantly, unless the note 5/confirmed (verified via instantX) means it worked. I'd rather see confirmation on the send page (so you don't have to try to change tabs) AND in the column with the ?. Is the blue ? new? If so, it's not noticeably different from a regular send.
