spork show!
Does this mean enforcement is on?
spork show!
DONE as wellDownloads - 11.1.21 Core - All Users
******** Please Update to 11.1.21 if you can, once that's done we can turn on enforcement *********
* No cold start needed
Source: https://github.com/darkcoin/darkcoin
Compiled Binaries: https://www.darkcoin.io/downloads/
Updates:
v0.11.1.20 - Limit IX to 1000DRK max for the time being
v0.11.1.21 - Fixed spork message propagation
Evan should have said "This is mandatory, update now!" :grin:******** Please Update to 11.1.21 if you can, once that's done we can turn on enforcement *********
Or put it in bold red:
:grin::grin:
Or put it in bold red: "ATTENTION MASTERNODE OPERATORS, IF YOU WANT TO GET RID OF CHEATERS, UPDATE NOW!"
:grin::grin:
Updated !!! one more masternode closer to enforcement...15% so far in two hours to 11.1.21
You can find info on Instantx from the OP of this thread:Looking to do a writeup about InstantX, anyone in the darkcoin community care to comment/answer a couple questions via PM, Email, or skype?
Well you could PM eduffield. :smile:Looking to do a writeup about InstantX, anyone in the darkcoin community care to comment/answer a couple questions via PM, Email, or skype?
Is there an official/Foundation PR spokesperson yet?
In the past he hasn't replied, but will try again.
you just need to write to [email protected] and you will get an answer fast.
Did update and reindexing work out for you?My nodes keep going offline with the corrupted block database detected message upon restart.
What should I do?
EDIT: I'm going to try the update and reindex thing...
What's inside d:\darkcoin\mn2\darkcoin.conf? Make sure you set it up correctly. Also there might be some file encoding issues - try to recreate conf file from scratch.since version 11.1.19 to 11.1.22 there is crash in win32 environment:
shortcut is:
D:\darkcoin\darkcoin-qt.exe -datadir=d:\darkcoin\data -wallet=wallet2.dat -conf=d:\darkcoin\mn2\darkcoin.conf
if I remove "-conf=d:\darkcoin\mn2\darkcoin.conf" all is fine, also if I use darkcoin-qt.exe ver 11.0.13.
But all works OK with this conf file if I get older version of darkcoin-qt.exeWhat's inside d:\darkcoin\mn2\darkcoin.conf? Make sure you set it up correctly. Also there might be some file encoding issues - try to recreate conf file from scratch.
