Orphaned blocks were not the issue of RC3 launch - actually they were expected. Outdated miners are supposed to create local forks, but as long as they do not get the majority of hashpower in the network these forks will get orphaned.I am pretty sure I am getting orphans because my solo rig works on a fork. Looks like we will be able to reproduce the issue. I think.
so versioni: v0.10.8.11-unk-beta should create a local fork?Orphaned blocks were not the issue of RC3 launch - actually they were expected. Outdated miners are supposed to create local forks, but as long as they do not get the majority of hashpower in the network these forks will get orphaned.
Yep, that's why every pool owner had to update to 0.10.10.1 before the hard fork. Any pool/miner not updating will get orphans - that's basically the idea of a hard forkso versioni: v0.10.8.11-unk-beta should create a local fork?
thxs flare. so much for my solo... actually one of my blocks did get accepted somehow.. but about 100 did not.Yep, that's why every pool owner had to update to 0.10.10.1 before the hard fork. Any pool/miner not updating will get orphans - that's basically the idea of a hard fork![]()
use -d (--device)Good job guys! Still trying to figure out how to config my miner so each card hashes on its own
-o stratum+tcp://127.0.0.1:3333 -u moQD1AbtbDgPhDCXhK5x9rkUQrTHK3ZE7H -p 1 \
--device 0 \
--worksize 256 \
-o stratum+tcp://54.183.73.24:3333 -u moQD1AbtbDgPhDCXhK5x9rkUQrTHK3ZE7H -p 1 \
--device 1 \
--worksize 256 \
central@ubuntu:~/.darkcoin$ darkcoind getinfo
"version" : 101002,
"protocolversion" : 70018,
"walletversion" : 60000,
"balance" : 0.00000000,
"blocks" : 500,
"timeoffset" : 0, "connections" : 0,
"proxy" : "",
"difficulty" : 0.53693007,
"testnet" : true,
"keypoololdest" : 1403529624,
"keypoolsize" : 101,
"paytxfee" : 0.00000000,
"mininput" : 0.00001000,
"errors" : "Hard Fork Alert: Masternode Payments begin on Friday. Please update! http://goo.gl/ucp4m7"
Ok, could I have a list of testnet pools please? I only have chaeplin's amazon NOMP. The "official" EC2 testnet MPOS does not work anymore.
Also, I fired up a VM Ubuntu I made, and its getting stuck on block 500, on --rescan get stuck on 1000. This seems to be happenig a lot, many poeple on IRC complain about the same issue. Also, I'm on 10.10.02, and I'm getting error message to "update for hard-fork on June 20th"
I've stopped and started a few times, stuck o 500, then 1000, the 1500. Zero connections. Only addnode:23xx.xx, masternode=0 ... weird
EDIT: Success, I finally got the syntax, thats chaeplin. -d has to go after the worker password. Pointed to your NOMP server, other 4 cards mining for real until I get other testnet pools
Simultaneous download limited to max 500 blocks.
-k x11mod -d 0 -o stratum+tcp://54.183.73.24:3333 -u mfxz2ZHLPW24msDY3PXrT5Wf1dj5YTDk1M -p 1 -d 1,2,3,4 -o stratum+tcp://mining.darkcointalk.org:3333 -u yidakee.1 -p x --auto-fan --gpu-fan 25-65 --temp-cutoff 92 --temp-overheat 88 --temp-target 64 -I 19 -g 1 -w 256 --lookup-gap 2 --thread-concurrency 8192 --gpu-powertune 20 --gpu-engine 1090 --gpu-memclock 1500
Use several scripts.Up to block now. But for some reason "-d" is not working properly. If I issue "-d 0", the other cards stay off. If I try "-d 1,2,3,4" with different pool info, it just point everything to "-d 0"
1.sh : - pool 1 : -d 0
2.sh : - pool 2 : -d 1
3.sh : - pool 3 : -d 2
Did you try to start several instances of the miner - one with '-d 0' and one with '-d 1'. Actually what chaeplin suggested above as several scripts.
Who needs a GUI anyway - always made the highest gains in my net worth when no GUI client was available at launchtime - so you are always better off when you know how to operate a crypto-client/miner via commandline :grin:Yes, and it worked. Makes sense not to be able to do it under 1 instance of sgminer. Also, CGWatcher does not like to run multiple instances, so its back to old trustworthy .bat files :tongue:
