TaoOfSatoshi
Together, we make Darkcoin the best cryptocurrency possible!
https://twitter.com/taoofsatoshi/status/538351749720182784
Well said! Keep up the good work guys!
I wouldn't say the number of running clients have any baring on whether or not a masternode should stay running and propagate.Could it be a lack of running clients?
Same here with MN.So has anyone been able to add their own MN's to the network? Mine have "Started Successfully", but don't propagate to the rest of the network. Also, the connection count is abysmal at 4 connections.
Can anyone explain why test-explorers are showing different addys?
http://test.explorer.masternode.io:18888 -shows X...
http://test.explorer.darkcoin.fr -shows correct for testnet m...
I am not much into it but can it couse a problem?:what:
I know that.The top one is screwed up because X addresses are found on mainnet and m & n addresses, testnet. Not sure how it happened, but the bottom one is accurate.
No idea, https://test.drk.mn/blocks.html matches up with the bottom test explorer as well. I'm curious how the top one was setup because the values of the addresses match up, as does the difficulty and hash yet the addresses generated are wrong.I know that.
But can it cause a problem?
It's just the addressversion which set to a wrong value on http://test.explorer.masternode.io:18888 - therefore the addresses are decoded wrong. Does not affect the functionality in any way.No idea, https://test.drk.mn/blocks.html matches up with the bottom test explorer as well. I'm curious how the top one was setup because the values of the addresses match up, as does the difficulty and hash yet the addresses generated are wrong.
That a typo in port (missing the last 9)?Guys, please expand a little on your setup, might help figure some stuff out.
For some reason I cannot "masternode start". Under a known VM Ubuntu 14.04 using the QT version, funded a blank 1k vin hot wallet, have the darkcoin config
set up nicely as usual, brand new masternode genkey, with or without externalip:xx.xx.xx.xx:1999.
"address_version": "\u004c"It's just the addressversion which set to a wrong value on http://test.explorer.masternode.io:18888 - therefore the addresses are decoded wrong. Does not affect the functionality in any way.
We chat in irc often. No biggie, is just a few minutes to get set up.
Got the credentials.. will install once we have the next version of 17.
Thanks again for contributing! The more nodes the merrier!
Thanks for pointing this out. Not sure how I missed that at first I was thinking that I was scraping a mainnet wallet by accident but the blocks match up so once someone can tell me what the address_version should be I'll fix it up. I haven't had to mess with address version yet? weird.Can anyone explain why test-explorers are showing different addys?
I am not much into it but can it cause a problem?:what:
Hey! My GPU is sweating for you and is mad now :wink:Heh a bunch of my earlier tx's turned up, a speedy 70 blocks later! 3 hours... service from miners is crap, can I get a refund?
I threatened my testnet i5 with a water pistol and told it, "Get a bloody move on, I know for a fact you can process ten bazillion FLOPS you lazy bastard!" but it called my bluff. :sad:Hey! My GPU is sweating for you and is mad now :wink:
