I tried it as well. I have denominated funds 8 rounds, some of them have 9 btw. When I tick darksend I can send every amount, but if I choose 2x10 in coin-control and try to send 10<amount<20 then It doesn't work. It says "unable to locate enough darksend denominated funds for this TX".On my windows machine, I have denominated funds, and I tried to send 13.54 drk to the Ubuntu address using 2 X 10 coin denominated coins. But I get the error " Unable to locate enough Darksend denominated funds for this transaction.
Back when I denominated these funds, a while ago... can't remember, I had it set for 8 rounds. It stopped around 6 rounds, and I never tried for more as there was a release. Now, I've re-set the rounds to 3. It may not like the change, or may not use higher denominated funds when you've set it lower? I don't know.
Status: 533 confirmations
Date: 11/29/14 03:47
Debit: 0.00 DRK
Credit: 0.00 DRK
Transaction fee: -0.008 DRK
Net amount: -0.008 DRK
Transaction ID: 03ffab60519cd61540496b9f3385dfdcd77f27361f8365323397bea7c8227845
2014-11-30 18:44:13 DoAutomaticDenominating : No funds detected in need of denominating (2)
Hi ya'all
I'm still confused. Are we testing the version of "change" that destroys the change? Either way, how do I see where the change goes please?![]()
- Disabled InstantX
17.x includes fixes to the dead change issue, masternode backwards compatibility, a simplier send coins interface and other improvements. It seems like everything is working really well except for InstantX (which is hit and miss), so I'd really like to make sure this release is solid as it stands and push it out to the network.
After we're sure these improvements work, we'll push out the changes and then jump right back into testing InstantX. For InstantX to work properly I need implement proof-of-service and have the masternode network passively scan itself and remove nodes that aren't online (which is causing most of our issues currently).
So let me know if there's anything else that needs to get fixed before release!
i had 6 wallets set for 970 / 4 rounds and they all stopped (constant idle status) around 83-86%
Once i'm back from work i will try to use coin control, bundle all n/a amounts and see if i cant
get a bit higher with the %.
014-12-01 13:23:18 DoAutomaticDenominating : No funds detected in need of denominating (2)
2014-12-01 13:23:27 ResendWalletTransactions()
2014-12-01 13:23:43 CDarkSendPool::UpdateState() == 3 | 3
2014-12-01 13:24:08 dstx: Got Masternode transaction b53dd31431a17aa7a3594c12bb059ab6f8f2850545cd76956043777d48496caa
2014-12-01 13:24:08 AcceptToMemoryPool: 95.85.48.49:19999 /Satoshi:0.10.17.4/ : accepted b53dd31431a17aa7a3594c12bb059ab6f8f2850545cd76956043777d48496caa (poolsz 14)
2014-12-01 13:24:20 DoAutomaticDenominating : No funds detected in need of denominating (2)
2014-12-01 13:25:21 DoAutomaticDenominating : No funds detected in need of denominating (2)
Alrighty then... QT says this;
But in reality;
At least yours does something....mine say "DoAutomaticDenominating : No funds detected in need of denominating (2)" but never start...
I guess it is a lot. Have to turn off this machine for now, if Evan needs it, it will be sent to him later.Ouch moli, that is a lot of collateral! Save that debug.log !
i see someone is hard at work on github![]()
