v0.10.17.x Testing
Thanks Flare! Was waiting on ".2"!
20 testnet nodes online:
$ seq -w 20 | p 'cd testnet; ./darkcoind -datadir=. masternode debug | tr "\n" " " ; ifconfig eth0 | grep "inet addr" | awk "{print \$2}" | sed -e "s/addr://"'
01 successfully started masternode 162.243.76.23
02 successfully started masternode 162.243.219.25
03 successfully started masternode 107.170.171.115
04 successfully started masternode 162.243.59.230
05 successfully started masternode 107.170.7.146
06 successfully started masternode 107.170.120.125
07 successfully started masternode 107.170.165.78
08 successfully started masternode 188.226.161.128
09 successfully started masternode 188.226.180.119
10 successfully started masternode 188.226.228.88
11 successfully started masternode 80.240.135.83
12 successfully started masternode 95.85.1.197
13 successfully started masternode 107.170.157.166
14 successfully started masternode 95.85.48.49
15 successfully started masternode 188.226.196.182
16 successfully started masternode 188.226.201.140
17 successfully started masternode 107.170.242.110
18 successfully started masternode 162.243.136.66
19 successfully started masternode 107.170.196.35
20 successfully started masternode 104.131.143.9
95.85.1.197
95.85.48.49
104.131.143.9
107.170.120.125
107.170.157.166
107.170.165.78
107.170.171.115
107.170.196.35
107.170.242.110
107.170.7.146
162.243.136.66
162.243.219.25
162.243.59.230
162.243.76.23
188.226.161.128
188.226.180.119
188.226.196.182
188.226.201.140
188.226.228.88
seq -w 20 | p 'cd testnet; ./darkcoind -datadir=. masternode debug'
Good stuff, another 14 incoming, sponsored by stonehedge
What do you think? Isn't that simpler.. 4 rounds set, 2 rounds done.
And we'll have a free place for a new section - solo mining or whatever.. ;)
I switched to way mo cheepah VPS and have $42.58 unused credit at vultr I'm probably never gonna use... How do I give that to somebody here?
Fire up 4 Ubuntu instances and provide me the IP/credentials- will add them to the testnet pool. $42.58 should be sufficient for 2 months of testing :)
i have been thinking about the 0.00 fees that we are getting when Darksend mixing, the transactions tab will be cluttered with them... maybe its possible to
make a seperate tab (lets call it Darksend Mixing Info for example) and have all 0.00 fees received in that specific tab ? (maybe put the 0.1 Darksend fees there as well ?)
you can compare it with how emailaccounts handle spam emails, they get stored in a seperate spamfolder... maybe something like this can be done in the darkcoin wallet ?
edit : i know we have filters that we can set in the transactions tab but if we could somehow get these darksend fees out of the transactions tab alltogether i think it would look better...
I tried sending an InstantX transaction to my node wallet, watched debug.log as it propagated. Saw this occur almost instantenously:
2014-11-29 09:00:32 ProcessMessageInstantX::txlreq - Already Have Transaction Lock Request: 107.170.120.125:59315 /Satoshi:0.10.17.2/ : accepted 4f4999d51684856be399f5139d4b9061cffec3f92b12998010081d1236b66f83
However the transaction didn't appear until the next block was hit by miners and seems to be confirming normally.
same here. (normal confirmation progression... didn't look at logs.)
But, on a different transaction got the full 6 confirmations and this odd square icon after just ONE block confirmation a few minutes earlier:
(successful instantx "ix-yidakee" ( mqLTmPQU2LkvNimUS4q8Z81XPKRgcfpHq4: 50 )
at time of (same!) block: 71488
http://test.explorer.darkcoin.fr/bl...48fe5763066ee60823b21c0f9161ae3b6e60c8adb5d39
( 18Mh got me a lot of blocks... :) )
I think my setup is still missing something, I have got no peers.dat or debug.log in my .darkcoin-testnet directory? everything is working, but where is the peers.dat he is using? Does he use my mainnet peers.dat and debug.log from .darkcoin directory? im already using -datadir and -conf parameter
testnet=1 in conf puts everything inside the testnet3 directory.
only your darkcoin.conf (as found by -datadir argument) is outside it.
You should have them independent of mainnet inside the testnet3 folder. But if you're using -datadir, then you're redirecting. Vanilla settings use ~/.darkcoin/testnet3/ for peers, chainstate, wallet, debug etc ... but it does look for ~/.darkcoin/darkcoin.conf for settings
Got distracted... but 4/6 confirms and its spendable (I think, I'am also denoming). Could be the cosmetic bug that Evan explains in the video! Nice... wanna go again?
I'm having trouble denoming 10DRK today. Stuck at 50%. Not concerned though. Testnet is small still.
Its hard to time transactions in seconds! Maybe the next version could have a timestamp that shows seconds?
Will send you another transaction now.
