GermanRed+
Active member
May I ask why Onyx v2 MN is not backward compatible with Onyx? There should not be any technical issues preventing that? Right?
Same here. I think they've been up less than an hour. At least I got a payment in that timeOK, MN:s dropped about after one hour, not good if need restart every hour.
Give people/pools time to upgrade.What was the point to turn the enforcement off?
Masternode payments for version 16.6+ have begun! This means, there will be no more payments for the old network until they update.
Enjoy the extra payments![]()
I'm running a hot/cold MN. "masternode debug" shows: "masternode started remotely"
MN list shows ~220MNs but I don't see my own IP
Have it running for ~18hours now on 16.6 and no payment so far (not that unusual)
Do I need to restart it because it's not in the MNlist or do I just have to wait?
I know, I'm not sure what he meant. I can only confirm that it is off (just checked).Weird because Evan wrote this on BTCtalk
Any info how fast they drop off the list?
"masternode started remotely" is when your cold wallet thinks that your mn that you are trying to start was already started. So you need to resync that list to get rid of cached mn ip.Fixed it with this:...
Why is there a rush to upgrade for v16 when v15 had a long waiting period to the enforcement? There is no reason to suddenly force people to upgrade immediately when v15 took 21 builds to become stable. The protocol should also be backward compatible until the v16 becomes stable.Give people/pools time to upgrade.
EDIT: Am I on ignore list or smth?
Because a problem was discovered in the Darksend protocol that could lead to transactions being traced through fees.Why is there a rush to upgrade for v16 when v15 had a long waiting period to the enforcement? There is no reason to suddenly force people to upgrade immediately when v15 took 21 builds to become stable. The protocol should also be backward compatible until the v16 becomes stable.
That's a job for Propulsion!Can somebody update the forum notice : "MN Enforcement was a success! Latest version 10.15.21 is available."
Yes and No.Because a problem was discovered in the Darksend protocol that could lead to transactions being traced through fees.
