No, not at all - v0.10.16.16 is pretty stable re. masternode list.My Local Remote Masternode Setup still gets dropped off the Masternodelist with the newest version... Anyone else having problems with local/remote?
I have to restart at least once a day. Both the Local and the Remote to get it back on the list.No, not at all - v0.10.16.16 is pretty stable re. masternode list.
Sure - please doI have to restart at least once a day. Both the Local and the Remote to get it back on the list.
I deleted peers.dat again and started a new debug.log and will monitor it now. When it drops off again maybe I can send the log to you or evan?
ok dropped off apparently.Sure - please do![]()
How much storage space do you have on your remote masternode? As it stands, v16 balloons up the debug.log. Not sure if this has anything to do with it or not.My Local Remote Masternode Setup still gets dropped off the Masternodelist with the newest version... Anyone else having problems with local/remote?
Usage of /: 41.0% of 7.75GBHow much storage space do you have on your remote masternode? As it stands, v16 balloons up the debug.log. Not sure if this has anything to do with it or not.
What type of guide? We have so many guides so they need to be categorized, like Masternode guides, Darksend guides, Mining guides.. etc.. Propulsion does the forum layout, and we went over this before, he's trying to organize categories so we can find topics better.offtopic: who does the forum layout, I think those 4 guides sections inside "Darkcoin Support" are *not good*one of my scripts even landed inside "Miscellaneous"
Can we have one primary "Guides" section inside "Darkcoin Support"?
The fix for this issue is already merged https://github.com/darkcoin/darkcoin/commit/d6e5ae3966c2769411383fcb638a3c928364a3efWith all this discussion on debug.log sizes, I went ahead and proactively deleted all my debug.logs on my MNs just to make sure my VPS' don't fill up. They were between 350MB and 900MB...significant but not problematic yet.
Reminder http://jira.darkcoin.qa/browse/DRK-58UdjinM6 Since Evan seems to be busy focusing on DS and you're tackling more of the fixes and features outside DS (until you get your hands dirty), can you put in a check against the percentage anonymized and if 100%, issue walletlock or the equivalent code basis. Having the wallet unlocked when the coins are already anon'd is just a security risk.
edit: I just checked and my node seems to be back on the list again. So maybe it only drops off temporarily from time to time. (Sent you the debug.log flare)
I did not find anything unusual in the debug.log - will forward to Evan.So checked again today. I'm again off the Masternode list...
Could you find anything in the debug.log?
Can you restart the node in the meantime? I do not find it on drk.mn.
edit: Hmm, seems to be an issue with drk.mn, not your node. As your node is back again, with uptime of >1d
It seems there is some kind of jitter in the list, as nodes dynamically enter and leave it. Judging on the list of payments your node received all is fine - the next payment should occur in the next hours.Ok so apparently it's just a cosmetic bug of the masternode list.
Cause drk.mn uses "darkcoind masternode list" or am I wrong?
And when I check the masternode list on my nodes I don't see my MN neither from time to time
So yeah, it seems like a cosmetic bug/minor bug of masternode list and how the peers maintain it. Peers should not remove nodes which have actively pinged durig the last 70mins. We will check that.
