Lebubar
Active member
One hour after...The trend seems to be that if you shut down your local wallet, it will go offline.
Heh, is this a new record?
we supposed to try this ?
Zero payments since yesterday !
He's still working on it..don't think its done.
tungfa...update to 16.8..and keep your local wallet on. I dont think anything below 16.6 is supposed to get paid any more.
Aaaaaalright! New patch suggestion :wink:
To let remote nodes correctly send dseep this line https://github.com/darkcoin/darkcoin/blob/master/src/activemasternode.cpp#L127 should be
Code:if(isCapableMasterNode != MASTERNODE_IS_CAPABLE && isCapableMasterNode != MASTERNODE_REMOTELY_ENABLED) return;
Also there is a bug in ThreadCheckDarkSendPool
https://github.com/darkcoin/darkcoin/blob/master/src/darksend.cpp#L1987
It would work fine if this https://github.com/darkcoin/darkcoin/blob/master/src/masternode.h#L35 wasn't an expression.
Right now it will start spam the network every 20 seconds and not minutes as it seems.
So these 4 lines https://github.com/darkcoin/darkcoin/blob/master/src/masternode.h#L34-L37 should be
It's only 2nd line that matters now but just to keep things consistent I would suggest to fix them all.Code:#define MASTERNODE_MIN_SECONDS (5*60) #define MASTERNODE_PING_SECONDS (20*60) #define MASTERNODE_EXPIRATION_SECONDS (65*60) #define MASTERNODE_REMOVAL_SECONDS (70*60) this
eduffield
Tested it, my nodes are stable since 1.5h now, ping sent every 20mins like clockwork, last seen on drk.mn max 20mins as well - awesome!Aaaaaalright! New patch suggestion :wink:
eduffield
Thank you! It's in my signUdjinM6, please post an address for donations as a thank you for your help.
Ok, I got it.. The best way to reach Evan is JIRA
16.11 is on it's way
https://github.com/darkcoin/darkcoin/commit/cbbd90f9a1d0346556b7490e9c0db3fb579aa5d9
darkcoin-0.10.16.10-win.zip:
https://github.com/darkcoinproject/darkcoin-binaries/blob/master/darkcoin-0.10.16.10-win.zip
