flare
You can download the file here - just put it in the folder %APPDATA%\DarkCoin
http://static.darkcoin.qa/doc/darkcoin.conf
BumpGood to know.
How about your masternode tool, are that going to public any time soon?
So am I setting up a normal masternode with a testnet wallet & chucking testnet=1 in the darkcoin.conf file? Port 9999 or 9998?
Correct, testnet p2p port is 19999, default rpc port is 19998 (just add 10000 to the mainnet ports)Isn't testnet port 19999?
sentAwesome. The binary switched to testnet version and I already added "setgenerate true". Please send me tDRK: mxsZhDvXNvqZ4bh1rfxDtsBCbVoZQovaPX
Easy tiger, you guys are on another level.i.e from remote terminal
darkcoind getaccount address 0 (send 1000 tDrk to that address)
etc etc
Added missing step in case of unaware.Easy tiger, you guys are on another level.
I stop my wallet in windows, rename the wallet.dat, put testnet=1 in the conf file, let it create a new wallet, send t1000 DRK to that wallet and FTP it into my VPS then change permissions...
All my Masternodes are hot wallets, I just use a long password...
I stop my wallet in windows, rename the wallet.dat, let it create a new wallet, send 1000 DRK to that wallet and FTP it into my VPS then change permissions...
No, that's fine, it just means your VPS can theoretically be accessed by someone else. Your local wallet is safe.I don't have a static IP and I wanna use AWS for remote for setting up MNs. Is it OK to set IP at "Anywhere" (0.0.0.0 or somehting like this) instead of "My IP"? Can this be used to steal the coins in my local wallet?
Are we still talking about testnet? You don't need to fear theft of testnet coins - i run every testnet node as hotI don't have a static IP and I wanna use AWS for remote for setting up MNs. Is it OK to set IP at "Anywhere" (0.0.0.0 or somehting like this) instead of "My IP"? Can this be used to steal the coins in my local wallet? Or as long as the local wallet encrypted, I shouldn't worry about it.
Where are you renting your hashing from?Sorry mate. I might be on another level but that level is probably below most people. I'm half informed, loaded, safety off and ready to fire off bad advice.
Are we still talking about testnet? You don't need to fear theft of testnet coins - i run every testnet node as hot![]()
