v0.10.13.x RC5 Testing
Can everyone run:
"getblockhash 32620"
It should say 0000000396252949e5f7e7a1c8dcfbc36591329668706540783e030f05d93add
Evan can you talk about whether RC5 is open source, etc. It's coming up a lot on Bitcointalk forums.
Can everyone run:
correct..
edit : unless you mean for us to check this on v0.10.13.11 ? (was checking on my still running v0.10.13.10)
I am version 13.03 and it is still good:
ubuntu@ip-10-252-35-58:~$ darkcoind getblockhash 32620
ubuntu@ip-10-252-35-58:~$ darkcoind getinfo
    "version" : 101303,
    "protocolversion" : 70037,
    "walletversion" : 60001,
    "balance" : 2331.92470007,
    "anonymized_balance" : 0.00000000,
    "blocks" : 32639,
    "timeoffset" : 0,
    "connections" : 39,
    "proxy" : "",
    "difficulty" : 0.24021245,
    "testnet" : true,
    "keypoololdest" : 1409802056,
    "keypoolsize" : 1001,
    "paytxfee" : 0.00000000,
    "mininput" : 0.00001000,
    "errors" : ""
****** PLEASE UPDATE TO v9.13.12 (Stable) OR 10.13.12 (RC) *******
The Warning message is being caused by older clients (pre-enforcement spork) still mining and they have the longer chain. The daemon should disconnect the two networks in the case of a rejected block.
- disconnect on rejecting enforced block
Stable Binaries
http://www.darkcoin.io/downloads/master-rc5/darkcoin-qt
http://www.darkcoin.io/downloads/master-rc5/darkcoind
RC5 Binaries
http://www.darkcoin.io/downloads/rc5/darkcoin-qt
http://www.darkcoin.io/downloads/rc5/darkcoind
now that we can run multiple Darkcoin clients on one PC we could test three-client pairing more easily..... just a thought.
just found out how to run multiple darkcoin clients on one PC for Windows users:
- make seperate folders for both darkcoin-qt.exe and the datafolders
- place shortcuts from each seperate darkcoin-qt.exe to yr desktop
- in each shortcut add following in the target field: -datadir=yrspecificdatadirectoryfolder -listen=0
voila... you can now run multiple darkcoin clients on one PC .. increasing the chance of finding pairs for all testers.
For non-windows users who want to try this see if you can do something with these parameters (-datadir & listen=0)
i have been running 2 darkcoin clients all night without problems, denominations coming in regarly.
Stable Binaries
RC5 Binaries
CI-builds for v0.9.13.12-g325b671
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-124/gitian-win-darkcoin-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...oin-bin/32/darkcoin-0.9.13.12-win32-setup.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRK-105/artifact/QTL/gitian-osx-darkcoin/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-103/gitian-linux-darkcoin-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-103/gitian-linux-darkcoin-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-103/gitian-linux-darkcoin-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-103/gitian-linux-darkcoin-bin/bin/64/darkcoind
CI-builds for v0.10.13.12-geb2eff3
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/...arkcoin-rc-darkcoin-qt-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...coin-rc-darkcoind-bin/32/daemon/darkcoind.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRKRC-42/artifact/QTL/gitian-osx-darkcoin-rc/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/64/darkcoind
BTW, my 16000 DRKs finished anonymizing last night after 78 hours, and a ton of "Darksend Denominate" fees.
Nothing new to report, I would feel comfy using this on main-net. Good work to the team and all testers!
Tao
I dont know if it's normale
I've updated the post with information about future plans, enforcement and open sourcing:
https://darkcointalk.org/threads/rc5-launching-september-22nd.2382/
Request for the following pre-opensource:
One of these was mentioned before, but I think the following two things are very important now that we are about to open-source.
1. Update the Darksend paper.
Mentioned before, I know -- but this is very important IMO. Once we open source a lot of people will turn their eyes towards Darkcoin. Some may look at the code, but most will just read the whitepaper... and the current paper does all the work Evan and the other devs have put in VERY little justice. It would suck to be called "just another coinjoin clone" based on an outdated whitepaper. PLEASE update this documentation before the 29th.
2. Darksend User Manual
Some attempts at this have been made in the past so maybe that can be used as a starting point, but having an updated manual with pictures and explanation based around the latest client will go a long way in mitigating confusion. This is probably more of an item for the "Core Team" rather than the dev team, but it is also very important.
Thanks
