I think there might be some problem with large amounts not split up properly so I'm testing this big amount, and when it's done, I'll test small amounts again.I'm still continuing my testing of smaller amounts because I feel many are testing large amounts but the amounts on mainnet will generally be smaller.
LOL jelly of all our sweet domains. I see what you did there...Testnet P2Pool moved. http://descartes.darkco.in:18998/
It was even 24% right after I started anonymization process. Had to dig into the settings (and hit apply) to refresh the GUI.Darksend Status = Disabled
Completition = 24%
on a brand new wallet with 0.0 funds. Default should be 0%?
I have upgraded to wallet 13.7 and my p2pool node is not happy. Before posting this I went back to wallet 13.5 and all was well with p2pool. When on 13.7 as soon as I start p2pool my debug.log from testnet get spammed with the following:
2014-09-11 00:19:48 maxconnections check 248
2014-09-11 00:19:48 accepted connection 127.0.0.1:47530
2014-09-11 00:19:48 partner 127.0.0.1:47530 using obsolete version 70018; disconnecting
2014-09-11 00:19:48 ProcessMessage(version, 122 bytes) FAILED
2014-09-11 00:19:48 disconnecting node 127.0.0.1:47530
The port increments each time but for whatever reason p2pool can't make the rpc connection. Not sure where this version 70018 is coming from. I have made no adjustments and all other services faucet and block explorer continue to work fine. Did some version number not get updated? Can someone help me understand wtf is going on?
2014-09-11 01:42:09 receive version message: /nodestratum/: version 70037, blocks=0, us=0.0.0.0:0, them=0.0.0.0:0, peer=11
Thanks! I edited line 22 of /p2pool-drk/p2pool/bitcoin/p2p.py from version=70018 to version=70500 that should do me for all the revision's to come after RC5 launchcheck https://bitbucket.org/dstorm/p2pool...0ee9adbb8b424/p2pool/bitcoin/p2p.py?at=master
change version=70018 to version=70040 (higher than 70035)
https://github.com/darkcoinproject/darkcoin/commit/c50784d0f6702053476fbc5cb020ab4ec1980f56
I will check my node-stratum.
Code:2014-09-11 01:42:09 receive version message: /nodestratum/: version 70037, blocks=0, us=0.0.0.0:0, them=0.0.0.0:0, peer=11
looks like nodestratum changes version by code.
settings 1900 tDRK / 8 roundsI have Options settings 5000 tdrk / 8 rounds. For several hours only 1000 tdrk got anonymized, and there are two large amounts of 4096 that have not split up. My guessing is there're not enough compatible denominations on testnet right now. But it seems large amounts have a hard time to anonymize.
Hey, thanks.settings 1900 tDRK / 8 rounds
Meaning that the peers use a random masternode for each round : if they were together in r1 (round 1) they may not be together in r2 etc."Use 3 clients in denominations to reduce the chance of sybil attacks.
This might cause a little blockchain bloat, but I think it's worth it."
http://jira.darkcoin.qa/browse/DRK-76
Would it be possible to connect to peers, partial mix, disconnect and mix with another set of peers as part of going around the master node network?
Meaning that the peers use a random masternode for each round : if they where together in r1 (round 1) they may not be together in r2 ?
Somehow I prefer the randomness, it could be more elegant.Yes.
If I try to snoop, I have no way to keep track.
If there are three peers as well, my data would become gibberish. I would have to set-up a sustained effort over a very long time to piece together a jigsaw puzzle, that might not yield any results.
Isn't this the way it already is?Meaning that the peers use a random masternode for each round : if they were together in r1 (round 1) they may not be together in r2 etc.
