bertlebbert
If you successfully copy wallet.dat from Dash to Dashcore, then 12.1 will open the copied wallet; it will definitely not open a brand new wallet. I would carefully re-try this method first.I'm having issues with getting the new version to show my balance and transactions.
I have copied over the wallet.dat file from Dash to DashCore but still no balance or transactions after the wallet is fully loaded?
I am running Mac OS
12.1 is just opening as a brand new wallet.
Is there a way I can go back change the directory to Dash so it recognizes old files rather than creates new?
Otherwise - yes, there is a way to specify Dash as your datadir.
