And translations?The roadmap was put together before IS issue was even discovered and it took a lot of time to find a proper way to fix it (initially we had another fix prepared btw). Anyway, all major tickets for 12.2 are closed now and everything (2mb blocks, lower fees, IS fix, and a whole bunch of internal fixes/backports/refactoring) seems to be working as designed. We are forking testnet right now to test migration process and to make sure that we didn't miss anything and dip0001 activation + network upgrade work well together (these were two separate events on "old" testnet). That's going to take few more days, not sure how long but at least 3 more. If no issues are found during this, then we are going to start migration at the very end of September (30th) or first days of October (more likely). Then it depends on how fast masternoders/miners are going to update so that dip0001 could lock in/activate and thus trigger other fixes. However, you should keep in mind that dip0001 lock in is going to require at least a week in any case, see https://github.com/dashpay/dips/blob/master/dip-0001.md#selection-of-parameters and _this_ is the earliest time we can turn IS back on. Considering how long it usually takes to update MNs, I'd say this day (of IS activation) is probably closer to mid of October.
Who and when?
