Can we expect anything from Kristov's feedback today?
Mintpal price is frozen for a couple of minutes now. Can this be because they are updating something?
This one is valid for updating, but use the new links instead of the old ones.Bah- I won't be able to update my masternode for a few hours - Does anyone have a guide for this so I can be as efficient as possible when I get home?
I see you have two darkcoin wallets open. Could this be the problem?Os is giving me problems on 10.12.25
cant see the ok button, press enter and i crashes
cant see the ok button, press enter and i crashes... but pressing right+enter, I guess it hits ok and works fine!
That seems like such an easy fix, plus not everyone will be impacted by it, and there is a workaround.just sucks that you can't see it... Hopefully that doesn't confuse anyone too much..
That seems like such an easy fix, plus not everyone will be impacted by it. And, there is a workaround.
You can check if your client version is updated on this list --> https://drk.mn/masternodes.htmlHow to verify my masternode is running? I got latest version and it says "successfully started masternode" but is there any thing else I could check?
I'm doing that but it is unlisted or inactive.You can check if your client version is updated on this list --> https://drk.mn/masternodes.html
