Don't know what its doing, but nothings changed.
It never finishes synching, was almost up to the actual height, but then started again at about 300 blocks earlier.
I'll remove the index now and start it again.
I have reproduced this on Windows 8 (RC4 client slow blockchain sync, high CPU load - 0.9.12.31 client works like charm) and created a bug ticket for this.Well, I gave up and killed it, after about 6 hours running at 100%.
The synching got very slow after about block 60.000.
It took about an hour to get there, and processed only about 15.000 blocks in the remaining five hours.
I'm back to 9.12.31 and it runs like it should.
Question. Sent a test to my wallet .31 and waited a day and it still shows my drk as non-anonymous. Did I do anything wrong here? Why isn't it letting me use my Drk as anonymous?
Is it the wallet version with Darksend? Have you checked to see if Darksend is not disabled?
Yup checked Disable Darksend. This should mean that it is enabled correct? Maxed out Drks to ananomize. Is there a typical waiting period?
That's the tricky thing. I'm not sure how long each wallet has to wait. You can ask on the RC4 Bugs thread for any problem you might have with the wallet.
When you check "Disable Darksend", it does just that... it disables it. You want to UNCHECK it (thus enabling Darksend).Yup checked Disable Darksend. This should mean that it is enabled correct? Maxed out Drks to ananomize. Is there a typical waiting period?
I see a problem.
I did denominate coins, made a backup after it just in case.
Now i bought some more cheap coins transfered in in to the wallet where also the denominated coins have been.
When i put in the old backup all the coins that has been denominated are gone, only the transfered coins are there.
Im lucky i made a backup, if not this coins would be gone? But this is not noob proofed and people have to know if they use darksend they have to make a new backup afterwards?
Thought 500 sub addresses are possible before you need a backup? So after you use darksend a new real address(private key) is generated?
Lol, no. A bot who is margin trading and doing both buying and selling is doing nothing but one thing to the price: nothing.As i figured, it looks like a bot on Cryptsey thats bringing the price down by manipulating its buy/sell orders etc. I can live with price manipulation because then we know the big whales are coming in to feast!
The addresses are generated on startup. So you need to backup all your wallets again after the RC4 launch.
