Thank youwas worried a bit
Sooo it`s time to bed now![]()
Same issue here -- seems like the coins are being mixed, but the number of rounds doesn't increase past 1 so denomination goes on forever. Has someone told Evan about this?
Ok so now it's been FIVE hours since last denominate transaction was created and it is still not confirmed. Where did it go wrong?
Yes, that's why it stopped creating more transactions i think, but the last one is stuck now and is not on the blockchain.Have you tried changing your Darksend rounds to 1 in the settings?
Now it says "darkSend Status => ERROR : missing input tx information" and is doing nothing. It tries to use that last transaction to denominate further, but it's not on the blockchain so i guess it just failsTry setting it back to the default 2. Maybe that will restart the denomination process and the coins will unlock.
Changed it back to 2 rounds and now it seems to be moving again.
Tried it and --salvagewallet returns only 500 drk instead of 623.6.Until the rounds issue is fixed, I would leave it on 2 until all your inputs in "coin control" show darksend rounds =1 AND no coins are unconfirmed and then switch it back to 1. That process worked for me.
If it is not on the blockchain then you may be having the same problem Camo was having on bitcointalk.
Problem:
https://bitcointalk.org/index.php?topic=421615.msg8342037#msg8342037
Solution:
https://bitcointalk.org/index.php?topic=421615.msg8342809#msg8342809
I redownloaded the whole blockchain with fresh wallet.dat file.Did you clear out the whole blockchain and redownload or just try --salvagewallet ?
I still don´t know how it works. Can someone please explain tom me.Does that mean your MN ( which is updated ) only get payments from pools that also have updated or doesn´t it matter which version they are running as long as your MN is on latest version ?
118735 was paid to a MN still running RC3 because that pool is still running RC3 and 118731 was paid to you instead of the other MN I think because there was some dispute in the voting, this time you got lucky but it can go either way.I still don´t know how it works. Can someone please explain tom me.
118731 was paid for me 118735 not
